Build signal-cli
Hello! I have been trying to get signal on my pinephone without using anbox. I am really happy about postmarketos, it is incredibly snappy and the phone functionality works very well.
I have tried to build signal-cli on the pinephone with the latest stable postmarketos 21.06. Glibc is required within the rust modules to build, so I tried to install: sgerrand/alpine-pkg-glibc and changing the target of rust from musl to gnu.
I managed to get the libsignal-client and libzkgroup compiled and I followed the instructions to bundle the .so files back in signal-cli.
Unfortunately when I then tried to run the signal-cli I get:
Missing required native library dependency: libsignal-client.
I had a look through the signal-cli issues and saw that this can happen when compiled with an older version of glibc. Not sure how this happened has the glibc version installed with sgerrand/alpine-pkg-glibc seems recent, but clearly I am missing something here...
I now just tried to do the same build on the pinebook pro with Manjaro. Everything compiled fine, it has and uses glibc rather than musl. I tried the signal-cli and it worked.
I then, maybe ignorantly thought I could copy and paste my build signal-cli from my pinebook pro ( with manjaro ) to my pinephone with postmarketos. They are both aarch64 after all.
I tried to run the signal-cli and again I got: Missing required native library dependency: libsignal-client.
It makes me very sad, in my ignorance I tried what I could but I am a bit lost now.
Is there someone that could help me understand what I am doing wrong and help me?
Thanks in advance Smile
(07-09-2021, 06:06 AM)uby89 Wrote: I managed to get the libsignal-client and libzkgroup compiled and I followed the instructions to bundle the .so files back in signal-cli.
edit: Unless I misunderstood you, you don't "bundle the .so files back in signal-cli". Instead you are removing the bundled libsignal_jni.so (and libzkgroup). Then it will look in your java library path for the ones you compiled/installed. Make sure they are in your java.library.path (run java -XshowSettings:properties to see)
Look here:
https://github.com/AsamK/signal-cli/wiki...-libsignal
specifically:
Quote:The linux x86_64 version is bundled by default. For other systems, you need to remove the bundled lib from the jar file
zip -d build/install/signal-cli/lib/signal-client-java-*.jar libsignal_jni.so
and please let me know if it works for you. I'm currently using an old version of signal-cli that was previously in Alpine edge (v 0.7.1)
Hi saba,
Thanks for your suggestion I tried it and unfortunately it didn't work. I am getting the same: Missing required native library dependency: libsignal-client.
I checked the java library path:
java.library.path = /usr/lib/jvm/java-11-openjdk/lib/server
        /usr/lib/jvm/java-11-openjdk/../lib
        /usr/java/packages/lib
        /lib
        /usr/lib
I put libsignal_jni.so and libzkgroup.so in /usr/java/packages/lib .
I had to create that folder and changed the group and owner to the phone user recursively for /usr/java.
I deleted those libs from the respective bundles.
Then I tried to link with the following command:
./build/install/signal-cli/bin/signal-cli link -n "pinephone"
But I got the missing required library error.
I will try again when a new version of signal-cli comes out. If you manage yourself please let me know Smile
  axolotl signal client on postmarket os? nieral 2 7,097 10-29-2021, 07:41 AM
Last Post: nieral
  Latest build no firefox, text editor? cosmicschock 2 4,950 10-03-2021, 12:19 PM
Last Post: cosmicschock
Wink Extremely fast pmOS build for the pinephone lucasanss 0 5,456 02-03-2021, 04:05 PM
Last Post: lucasanss
  Build state today firefox-58 3 8,534 10-24-2020, 08:48 AM
Last Post: jmorris
  Signal on PostmarketOS GloriousCoffee 8 18,860 09-01-2020, 07:37 AM
Last Post: nieral
  pmbootstrap build large keyboard not usable u20200719 5 12,197 07-25-2020, 02:31 PM
Last Post: u20200719
