systen type not detected (config.guess, config.sub, LMS 7.9 install
hello,
I'm trying to install Logitechmediaserver on my new Pine A64+, 2GB. I'm now using this :Ubuntu Linux Image [20160502] based on Longsleep build, updated by Pine64.
I tried with Debian base and Xenial from pine64.org too.
I end up with some modules not loading. I have tried to use different versions of Perl (originally5.22) and building the CPAN modules myself (buildme.sh). No luck. It seems that config.guess and config.sub  included in those numerous tars are not able to detect the system. Is there any known  workround for this?
I intend to use PINE as my LMS server, so any distro as basis is enough for me. No need for GUI even
I'm NOT an expert so probably I'm doing something trivially wrong
(05-18-2016, 01:29 AM)mrpn900 Wrote: hello,
Read those config.* files, at the top is the URL of the latest version. Replace the files with the latest version and try again.
forgot to mention that I already downlaoded and used the latest version of configxxxx-files with no luck. I used the new config-files by adding system type info manually. I entered this only once though when running buildme.sh. I shall have to try running each module build one by one, with manual config.sub arguments.
I just wonder what is special with PINE that these configs do not recognize PINEs. Should somebody tell somebody that this kind of equipment exists?
  Install Telegram Desktop in KDE Neon podcastlinux 2 10,631 01-26-2020, 01:43 AM
Last Post: giga
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 7,649 02-22-2017, 06:50 AM
Last Post: MarkHaysHarris777
  install lvs jam 2 6,276 11-30-2016, 01:33 AM
Last Post: jam
Question Step By Step How To Install Ubuntu Image damikeh 47 197,959 10-01-2016, 07:15 PM
Last Post: jkmooney
  How do i install python anaconda on my ubuntu ? quantumfusion 3 10,309 08-22-2016, 08:07 AM
Last Post: martinayotte
  Unmet dependencies/held broken packages while trying to install kodi fencerjared 2 8,962 06-25-2016, 06:38 AM
Last Post: fencerjared
  in search for the /boot/config-...... file pelgrim 19 35,053 05-31-2016, 07:07 AM
Last Post: pelgrim
  System program problem detected error ebclr 0 3,671 05-15-2016, 09:18 PM
Last Post: ebclr
  Can't install plex or chrome Thorzgard 5 11,447 05-03-2016, 03:37 PM
Last Post: eluder
