Screen or motherboard replacement?
Good day,
I have an issue with my UB Ports CE PinePhone. I am trying to figure out if I need to replace just the screen, or if the motherboard needs to be replaced as well.
At one point, I cracked my screen, but it still worked for the longest time. I did remove the two components for the VCONN issue, and again, it worked fine.
I think I may have damaged the phone further recently when I accidently stepped on it :| The touch screen does not function any more, but I can use a keyboard/mouse just fine.
I have tried two different distros that had previously worked, Manjaro and Mobian.
Here is the output from the serial console on bootup with Manjaro. The transfer errors just continue on and on.
U-Boot SPL 2020.07-rc4-11.1 (Jan 15 2021 - 11:52:57 +0000) DRAM: 2048 MiB Trying to boot from MMC2 NOTICE:  BL31: v2.3(debug): NOTICE:  BL31: Built : 11:52:57, Jan 15 2021 NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689) NOTICE:  BL31: Found U-Boot DTB at 0x4064908, model: Pine64 PinePhone (1.2) INFO:    ARM GICv2 driver initialized INFO:    Configuring SPC Controller INFO:    PMIC: Probing AXP803 on RSB INFO:    PMIC: dcdc1 voltage: 3.300V INFO:    PMIC: dcdc5 voltage: 1.200V INFO:    PMIC: dcdc6 voltage: 1.100V INFO:    PMIC: dldo1 voltage: 3.300V INFO:    PMIC: dldo2 voltage: 1.800V INFO:    PMIC: dldo3 voltage: 2.800V INFO:    BL31: Platform setup done INFO:    BL31: Initializing runtime services INFO:    BL31: cortex_a53: CPU workaround for 843419 was applied INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied NOTICE:  PSCI: System suspend is available via SCPI INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x4a000000 INFO:    SPSR = 0x3c9 U-Boot 2020.07-rc4-11.1 (Jan 15 2021 - 11:52:57 +0000) Manjaro Linux ARM CPU:   Allwinner A64 (SUN50I) Model: Pine64 PinePhone (1.2) DRAM:  2 GiB MMC:   Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment In:    serial@1c28000 Out:   serial@1c28000 Err:   serial@1c28000 starting USB... No working controllers found Hit any key to stop autoboot:  0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot.scr 975 bytes read in 2 ms (475.6 KiB/s) ## Executing script at 4fc00000 gpio: pin 98 (gpio 98) value is 1 gpio: pin 114 (gpio 114) value is 1 19042312 bytes read in 816 ms (22.3 MiB/s) gpio: pin 98 (gpio 98) value is 0 50338 bytes read in 4 ms (12 MiB/s) 7115010 bytes read in 306 ms (22.2 MiB/s) gpio: pin 115 (gpio 115) value is 1 ## Flattened Device Tree blob at 4fa00000    Booting using the fdt blob at 0x4fa00000    Loading Ramdisk to 49936000, end 49fff102 ... OK    Loading Device Tree to 0000000049926000, end 00000000499354a1 ... OK Starting kernel ... [    0.743254] SMCCC: SOC_ID: ARCH_SOC_ID(0) returned error: ffffffffffffffff [    0.949111] phy id_det change to device [    1.108247] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [    1.117505] Goodix-TS 1-005d: I2C transfer error: -5 [    1.165647] Goodix-TS 1-005d: I2C transfer error: -6 Starting version 247.2-1-arch [    1.223682] Goodix-TS 1-005d: I2C transfer error: -6 [    1.279984] Goodix-TS 1-005d: I2C transfer error: -6 [    1.337237] Goodix-TS 1-005d: I2C transfer error: -6 [    1.393687] Goodix-TS 1-005d: I2C transfer error: -6 [    1.452104] Goodix-TS 1-005d: I2C transfer error: -6 [    1.507959] Goodix-TS 1-005d: I2C transfer error: -6 [    1.565771] Goodix-TS 1-005d: I2C transfer error: -6 [    1.680088] Goodix-TS 1-005d: I2C transfer error: -6 [    1.737207] Goodix-TS 1-005d: I2C transfer error: -6 [    1.795128] Goodix-TS 1-005d: I2C transfer error: -6 [    1.850818] Goodix-TS 1-005d: I2C transfer error: -6 [    1.907973] Goodix-TS 1-005d: I2C transfer error: -6 ROOT_MNJRO: recovering journal [    1.965623] Goodix-TS 1-005d: I2C transfer error: -6 [    2.022031] Goodix-TS 1-005d: I2C transfer error: -6 [    2.079073] Goodix-TS 1-005d: I2C transfer error: -6 ROOT_MNJRO: Clearing orphaned inode 300282 (uid=1000, gid=985, mode=0100644, size=6219) ROOT_MNJRO: Clearing orphaned inode 299306 (uid=1000, gid=985, mode=0100644, size=6083) ROOT_MNJRO: Clearing orphaned inode 300297 (uid=1000, gid=985, mode=0100644, size=6219) ROOT_MNJRO: clean, 237786/942848 files, 1304677/3785691 blocks [    2.136192] Goodix-TS 1-005d: I2C transfer error: -6 [    2.193399] Goodix-TS 1-005d: I2C transfer error: -6 [    2.308967] Goodix-TS 1-005d: I2C transfer error: -6 [    2.365583] Goodix-TS 1-005d: I2C transfer error: -6 [    2.421604] Goodix-TS 1-005d: I2C transfer error: -6 [    2.478713] Goodix-TS 1-005d: I2C transfer error: -6 [    2.594517] Goodix-TS 1-005d: I2C transfer error: -6 [    2.650664] Goodix-TS 1-005d: I2C transfer error: -6 [    2.707077] Goodix-TS 1-005d: I2C transfer error: -6 [    2.764383] Goodix-TS 1-005d: I2C transfer error: -6 [    2.821566] Goodix-TS 1-005d: I2C transfer error: -6 [    2.879944] Goodix-TS 1-005d: I2C transfer error: -6 [    2.935087] Goodix-TS 1-005d: I2C transfer error: -6 [    2.992441] Goodix-TS 1-005d: I2C transfer error: -6 [    3.049544] Goodix-TS 1-005d: I2C transfer error: -6 [    3.106619] Goodix-TS 1-005d: I2C transfer error: -6 [    3.163729] Goodix-TS 1-005d: I2C transfer error: -6 [    3.221611] Goodix-TS 1-005d: I2C transfer error: -6 [    3.277700] Goodix-TS 1-005d: I2C transfer error: -6 [    3.335605] Goodix-TS 1-005d: I2C transfer error: -6 [    3.392256] Goodix-TS 1-005d: I2C transfer error: -6 [    3.449762] Goodix-TS 1-005d: I2C transfer error: -6 [    3.505827] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [    3.515424] Goodix-TS 1-005d: I2C transfer error: -5 [    3.564435] Goodix-TS 1-005d: I2C transfer error: -6 [    3.621238] Goodix-TS 1-005d: I2C transfer error: -6 [    3.677666] Goodix-TS 1-005d: I2C transfer error: -6 [    3.735968] Goodix-TS 1-005d: I2C transfer error: -6 [    3.792143] Goodix-TS 1-005d: I2C transfer error: -6 [    3.849416] Goodix-TS 1-005d: I2C transfer error: -6 [    3.905683] Goodix-TS 1-005d: I2C transfer error: -6 [    3.963611] Goodix-TS 1-005d: I2C transfer error: -6 [    4.020095] Goodix-TS 1-005d: I2C transfer error: -6 [    4.077752] Goodix-TS 1-005d: I2C transfer error: -6 [    4.133790] Goodix-TS 1-005d: I2C transfer error: -6 [    4.192136] Goodix-TS 1-005d: I2C transfer error: -6 [    4.248090] Goodix-TS 1-005d: I2C transfer error: -6 [    4.305708] Goodix-TS 1-005d: I2C transfer error: -6 [    4.419782] Goodix-TS 1-005d: I2C transfer error: -6 [    4.477676] Goodix-TS 1-005d: I2C transfer error: -6 [    4.592277] Goodix-TS 1-005d: I2C transfer error: -6 [    4.648126] Goodix-TS 1-005d: I2C transfer error: -6 [    4.705695] Goodix-TS 1-005d: I2C transfer error: -6 [    4.705753] Goodix-TS 1-005d: I2C write end_cmd error [    4.761707] Goodix-TS 1-005d: I2C transfer error: -6 [    4.761761] Goodix-TS 1-005d: I2C write end_cmd error [    4.761950] Goodix-TS 1-005d: I2C transfer error: -6 [    4.761991] Goodix-TS 1-005d: I2C write end_cmd error [    4.762195] Goodix-TS 1-005d: I2C transfer error: -6 [    4.762238] Goodix-TS 1-005d: I2C write end_cmd error [    4.795666] debugfs: File 'Playback' in directory 'dapm' already present! [    4.795683] debugfs: File 'Capture' in directory 'dapm' already present! [    4.820131] Goodix-TS 1-005d: I2C transfer error: -6 [    4.820209] Goodix-TS 1-005d: I2C write end_cmd error [    4.876240] Goodix-TS 1-005d: I2C transfer error: -6 [    4.876304] Goodix-TS 1-005d: I2C write end_cmd error [    4.876407] Goodix-TS 1-005d: I2C transfer error: -6 [    4.876450] Goodix-TS 1-005d: I2C write end_cmd error [    4.933185] Goodix-TS 1-005d: I2C transfer error: -6 [    4.933242] Goodix-TS 1-005d: I2C write end_cmd error [    4.933471] Goodix-TS 1-005d: I2C transfer error: -6 [    4.933556] Goodix-TS 1-005d: I2C write end_cmd error [    4.991211] Goodix-TS 1-005d: I2C transfer error: -6 [    4.991269] Goodix-TS 1-005d: I2C write end_cmd error [    5.048087] Goodix-TS 1-005d: I2C transfer error: -6 [    5.048139] Goodix-TS 1-005d: I2C write end_cmd error [    5.105696] Goodix-TS 1-005d: I2C transfer error: -6 [    5.105750] Goodix-TS 1-005d: I2C write end_cmd error [    5.276472] Goodix-TS 1-005d: I2C transfer error: -6 [    5.389702] Goodix-TS 1-005d: I2C transfer error: -6 [    5.447774] Goodix-TS 1-005d: I2C transfer error: -6 [    5.504209] Goodix-TS 1-005d: I2C transfer error: -6 [    5.561720] Goodix-TS 1-005d: I2C transfer error: -6 [    5.618848] Goodix-TS 1-005d: I2C transfer error: -6 [    5.675964] Goodix-TS 1-005d: I2C transfer error: -6 [    5.676017] Goodix-TS 1-005d: I2C write end_cmd error [    5.733220] Goodix-TS 1-005d: I2C transfer error: -6 [    5.733285] Goodix-TS 1-005d: I2C write end_cmd error [    5.790876] Goodix-TS 1-005d: I2C transfer error: -6 [    5.790932] Goodix-TS 1-005d: I2C write end_cmd error [    5.847632] Goodix-TS 1-005d: I2C transfer error: -6 [    5.905394] Goodix-TS 1-005d: I2C transfer error: -6 [    5.961771] Goodix-TS 1-005d: I2C transfer error: -6 [    6.017714] Goodix-TS 1-005d: I2C transfer error: -6 [    6.074785] Goodix-TS 1-005d: I2C transfer error: -6 [    6.133145] Goodix-TS 1-005d: I2C transfer error: -6 [    6.189169] Goodix-TS 1-005d: I2C transfer error: -6 [    6.245946] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [    6.255266] Goodix-TS 1-005d: I2C transfer error: -5 [    6.303627] Goodix-TS 1-005d: I2C transfer error: -6 [    6.361241] Goodix-TS 1-005d: I2C transfer error: -6 [    6.417230] Goodix-TS 1-005d: I2C transfer error: -6 [    6.476159] Goodix-TS 1-005d: I2C transfer error: -6 [    6.532230] Goodix-TS 1-005d: I2C transfer error: -6 [    6.532293] Goodix-TS 1-005d: I2C write end_cmd error [    6.589350] Goodix-TS 1-005d: I2C transfer error: -6 [    6.589403] Goodix-TS 1-005d: I2C write end_cmd error [    6.645704] Goodix-TS 1-005d: I2C transfer error: -6 [    6.704273] Goodix-TS 1-005d: I2C transfer error: -6 [    6.760202] Goodix-TS 1-005d: I2C transfer error: -6 [    6.818800] Goodix-TS 1-005d: I2C transfer error: -6 [    6.931792] Goodix-TS 1-005d: I2C transfer error: -6 [    6.988338] Goodix-TS 1-005d: I2C transfer error: -6 [    7.045668] Goodix-TS 1-005d: I2C transfer error: -6 [    7.104193] Goodix-TS 1-005d: I2C transfer error: -6 [    7.160152] Goodix-TS 1-005d: I2C transfer error: -6 [    7.217274] Goodix-TS 1-005d: I2C transfer error: -6 [    7.273677] Goodix-TS 1-005d: I2C transfer error: -6 [    7.273735] Goodix-TS 1-005d: I2C write end_cmd error [    7.274041] Goodix-TS 1-005d: I2C transfer error: -6 [    7.274127] Goodix-TS 1-005d: I2C write end_cmd error [    7.331746] Goodix-TS 1-005d: I2C transfer error: -6 [    7.388063] Goodix-TS 1-005d: I2C transfer error: -6 [    7.445668] Goodix-TS 1-005d: I2C transfer error: -6 [    7.503428] Goodix-TS 1-005d: I2C transfer error: -6 [    7.560701] Goodix-TS 1-005d: I2C transfer error: -6 [    7.616100] Goodix-TS 1-005d: I2C transfer error: -6 [    7.673609] Goodix-TS 1-005d: I2C transfer error: -6 [    7.732185] Goodix-TS 1-005d: I2C transfer error: -6 [    7.787998] Goodix-TS 1-005d: I2C transfer error: -6 [    7.845266] Goodix-TS 1-005d: I2C transfer error: -6 [    7.845503] Goodix-TS 1-005d: I2C write end_cmd error [    7.901842] Goodix-TS 1-005d: I2C transfer error: -6 [    7.901903] Goodix-TS 1-005d: I2C write end_cmd error [    7.959958] Goodix-TS 1-005d: I2C transfer error: -6 [    8.016726] Goodix-TS 1-005d: I2C transfer error: -6 [    8.074402] Goodix-TS 1-005d: I2C transfer error: -6 [    8.130302] Goodix-TS 1-005d: I2C transfer error: -6 [    8.187305] Goodix-TS 1-005d: I2C transfer error: -6 [    8.243966] Goodix-TS 1-005d: I2C transfer error: -6 [    8.301631] Goodix-TS 1-005d: I2C transfer error: -6 [    8.359977] Goodix-TS 1-005d: I2C transfer error: -6 [    8.415960] Goodix-TS 1-005d: I2C transfer error: -6 [    8.472710] Goodix-TS 1-005d: I2C transfer error: -6 [    8.531085] Goodix-TS 1-005d: I2C transfer error: -6 [    8.531137] Goodix-TS 1-005d: I2C write end_cmd error [    8.587945] Goodix-TS 1-005d: I2C transfer error: -6 [    8.587995] Goodix-TS 1-005d: I2C write end_cmd error [    8.644085] Goodix-TS 1-005d: I2C transfer error: -6 [    8.701585] Goodix-TS 1-005d: I2C transfer error: -6 [    8.757960] Goodix-TS 1-005d: I2C write end_cmd error [    8.815315] Goodix-TS 1-005d: I2C transfer error: -6 [    8.872010] Goodix-TS 1-005d: I2C transfer error: -6 [    8.929600] Goodix-TS 1-005d: I2C transfer error: -6 [    8.987964] Goodix-TS 1-005d: I2C transfer error: -6 [    9.043528] Goodix-TS 1-005d: I2C transfer error: -6 [    9.100617] Goodix-TS 1-005d: I2C transfer error: -6 [    9.157689] Goodix-TS 1-005d: I2C transfer error: -6 [    9.214792] Goodix-TS 1-005d: I2C transfer error: -6 [    9.272853] Goodix-TS 1-005d: I2C transfer error: -6 [    9.328978] Goodix-TS 1-005d: I2C transfer error: -6 [    9.386011] Goodix-TS 1-005d: I2C transfer error: -6 [    9.444174] Goodix-TS 1-005d: I2C transfer error: -6 [    9.557473] Goodix-TS 1-005d: I2C transfer error: -6 [    9.614602] Goodix-TS 1-005d: I2C transfer error: -6 [    9.671405] Goodix-TS 1-005d: I2C transfer error: -6 [    9.729616] Goodix-TS 1-005d: I2C transfer error: -6 [    9.842797] Goodix-TS 1-005d: I2C transfer error: -6 [    9.900212] Goodix-TS 1-005d: I2C transfer error: -6 [    9.957593] Goodix-TS 1-005d: I2C transfer error: -6 [   10.013584] Goodix-TS 1-005d: I2C transfer error: -6 [   10.072001] Goodix-TS 1-005d: I2C transfer error: -6 [   10.127995] Goodix-TS 1-005d: I2C transfer error: -6 [   10.185301] Goodix-TS 1-005d: I2C transfer error: -6 [   10.241894] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   10.251189] Goodix-TS 1-005d: I2C transfer error: -5 [   10.301000] Goodix-TS 1-005d: I2C transfer error: -6 [   10.356433] Goodix-TS 1-005d: I2C transfer error: -6 [   10.413550] Goodix-TS 1-005d: I2C transfer error: -6 [   10.470628] Goodix-TS 1-005d: I2C transfer error: -6 [   10.528747] Goodix-TS 1-005d: I2C transfer error: -6 [   10.584793] Goodix-TS 1-005d: I2C transfer error: -6 [   10.641905] Goodix-TS 1-005d: I2C transfer error: -6 [   10.699929] Goodix-TS 1-005d: I2C transfer error: -6 [   10.755946] Goodix-TS 1-005d: I2C transfer error: -6 [   10.813186] Goodix-TS 1-005d: I2C transfer error: -6 [   10.870224] Goodix-TS 1-005d: I2C transfer error: -6 [   10.927285] Goodix-TS 1-005d: I2C transfer error: -6 [   10.984030] Goodix-TS 1-005d: I2C transfer error: -6 [   11.041140] Goodix-TS 1-005d: I2C transfer error: -6 [   11.100010] Goodix-TS 1-005d: I2C transfer error: -6 [   11.155863] Goodix-TS 1-005d: I2C transfer error: -6 [   11.213625] Goodix-TS 1-005d: I2C transfer error: -6 [   11.269583] Goodix-TS 1-005d: I2C transfer error: -6 [   11.328021] Goodix-TS 1-005d: I2C transfer error: -6 [   11.384241] Goodix-TS 1-005d: I2C transfer error: -6 [   11.441702] Goodix-TS 1-005d: I2C transfer error: -6 [   11.497817] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   11.507080] Goodix-TS 1-005d: I2C transfer error: -5 [   11.555841] Goodix-TS 1-005d: I2C transfer error: -6 [   11.612019] Goodix-TS 1-005d: I2C transfer error: -6 [   11.669640] Goodix-TS 1-005d: I2C transfer error: -6 [   11.728052] Goodix-TS 1-005d: I2C transfer error: -6 [   11.783255] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   11.792499] Goodix-TS 1-005d: I2C transfer error: -5 [   11.840743] Goodix-TS 1-005d: I2C transfer error: -6 [   11.897787] Goodix-TS 1-005d: I2C transfer error: -6 [   11.954956] Goodix-TS 1-005d: I2C transfer error: -6 [   12.012041] Goodix-TS 1-005d: I2C transfer error: -6 [   12.126146] Goodix-TS 1-005d: I2C transfer error: -6 [   12.183330] Goodix-TS 1-005d: I2C transfer error: -6 [   12.240454] Goodix-TS 1-005d: I2C transfer error: -6 [   12.297569] Goodix-TS 1-005d: I2C transfer error: -6 Manjaro Linux 5.10.7-1-MANJARO-ARM (ttyS0) manjaro-arm login: [   12.354500] Goodix-TS 1-005d: I2C transfer error: -6 [   12.411690] Goodix-TS 1-005d: I2C transfer error: -6 [   12.468891] Goodix-TS 1-005d: I2C transfer error: -6 [   12.527278] Goodix-TS 1-005d: I2C transfer error: -6 [   12.583039] Goodix-TS 1-005d: I2C transfer error: -6 [   12.639994] Goodix-TS 1-005d: I2C transfer error: -6 [   12.697052] Goodix-TS 1-005d: I2C transfer error: -6 [   12.754244] Goodix-TS 1-005d: I2C transfer error: -6 [   12.811325] Goodix-TS 1-005d: I2C transfer error: -6 [   12.868360] Goodix-TS 1-005d: I2C transfer error: -6 [   12.925446] Goodix-TS 1-005d: I2C transfer error: -6 [   12.982523] Goodix-TS 1-005d: I2C transfer error: -6 [   13.039942] Goodix-TS 1-005d: I2C transfer error: -6 [   13.096718] Goodix-TS 1-005d: I2C transfer error: -6 [   13.155105] Goodix-TS 1-005d: I2C transfer error: -6 [   13.211031] Goodix-TS 1-005d: I2C transfer error: -6 [   13.268026] Goodix-TS 1-005d: I2C transfer error: -6 [   13.325041] Goodix-TS 1-005d: I2C transfer error: -6 [   13.382124] Goodix-TS 1-005d: I2C transfer error: -6 [   13.439219] Goodix-TS 1-005d: I2C transfer error: -6 [   13.496309] Goodix-TS 1-005d: I2C transfer error: -6 [   13.553429] Goodix-TS 1-005d: I2C transfer error: -6 [   13.611471] Goodix-TS 1-005d: I2C transfer error: -6 [   13.667163] Goodix-TS 1-005d: I2C transfer error: -6 [   13.724849] Goodix-TS 1-005d: I2C transfer error: -6 [   13.782882] Goodix-TS 1-005d: I2C transfer error: -6 [   13.840180] Goodix-TS 1-005d: I2C transfer error: -6 [   13.897295] Goodix-TS 1-005d: I2C transfer error: -6 [   14.009698] Goodix-TS 1-005d: I2C transfer error: -6 [   14.068107] Goodix-TS 1-005d: I2C transfer error: -6 [   14.124513] Goodix-TS 1-005d: I2C transfer error: -6 [   14.181603] Goodix-TS 1-005d: I2C transfer error: -6 [   14.238667] Goodix-TS 1-005d: I2C transfer error: -6 [   14.296148] Goodix-TS 1-005d: I2C transfer error: -6 [   14.353379] Goodix-TS 1-005d: I2C transfer error: -6 [   14.409714] Goodix-TS 1-005d: I2C transfer error: -6 [   14.467672] Goodix-TS 1-005d: I2C transfer error: -6 [   14.524221] Goodix-TS 1-005d: I2C transfer error: -6 [   14.581260] Goodix-TS 1-005d: I2C transfer error: -6 [   14.637727] Goodix-TS 1-005d: I2C transfer error: -6 [   14.696265] Goodix-TS 1-005d: I2C transfer error: -6 [   14.752214] Goodix-TS 1-005d: I2C transfer error: -6 [   14.809877] Goodix-TS 1-005d: I2C transfer error: -6 [   14.923837] Goodix-TS 1-005d: I2C transfer error: -6 [   14.981320] Goodix-TS 1-005d: I2C transfer error: -6 [   15.037254] Goodix-TS 1-005d: I2C transfer error: -6 [   15.096176] Goodix-TS 1-005d: I2C transfer error: -6 [   15.152174] Goodix-TS 1-005d: I2C transfer error: -6 [   15.209231] Goodix-TS 1-005d: I2C transfer error: -6 [   15.265708] Goodix-TS 1-005d: I2C transfer error: -6 [   15.324139] Goodix-TS 1-005d: I2C transfer error: -6 [   15.380242] Goodix-TS 1-005d: I2C transfer error: -6 [   15.438695] Goodix-TS 1-005d: I2C transfer error: -6 [   15.493917] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   15.503337] Goodix-TS 1-005d: I2C transfer error: -5 [   15.551713] Goodix-TS 1-005d: I2C transfer error: -6 [   15.609130] Goodix-TS 1-005d: I2C transfer error: -6 [   15.665725] Goodix-TS 1-005d: I2C transfer error: -6 [   15.722696] Goodix-TS 1-005d: I2C transfer error: -6 [   15.780177] Goodix-TS 1-005d: I2C transfer error: -6 [   15.837128] Goodix-TS 1-005d: I2C transfer error: -6 [   15.893671] Goodix-TS 1-005d: I2C transfer error: -6 [   15.952131] Goodix-TS 1-005d: I2C transfer error: -6 [   16.005610] modem-power serial1-0: The modem looks kill-switched [   16.008073] Goodix-TS 1-005d: I2C transfer error: -6 [   16.016778] modem-power serial1-0: power up failed [   16.065641] Goodix-TS 1-005d: I2C transfer error: -6 [   16.179840] Goodix-TS 1-005d: I2C transfer error: -6 [   16.237129] Goodix-TS 1-005d: I2C transfer error: -6 [   16.293723] Goodix-TS 1-005d: I2C transfer error: -6 [   16.350860] Goodix-TS 1-005d: I2C transfer error: -6 [   16.408205] Goodix-TS 1-005d: I2C transfer error: -6 [   16.465730] Goodix-TS 1-005d: I2C transfer error: -6 [   16.522700] Goodix-TS 1-005d: I2C transfer error: -6 [   16.579839] Goodix-TS 1-005d: I2C transfer error: -6 [   16.636116] Goodix-TS 1-005d: I2C transfer error: -6 [   16.694778] Goodix-TS 1-005d: I2C transfer error: -6 [   16.808619] Goodix-TS 1-005d: I2C transfer error: -6 [   16.865724] Goodix-TS 1-005d: I2C transfer error: -6 [   16.921698] Goodix-TS 1-005d: I2C transfer error: -6 [   16.978720] Goodix-TS 1-005d: I2C transfer error: -6 [   17.037227] Goodix-TS 1-005d: I2C transfer error: -6 [   17.093417] Goodix-TS 1-005d: I2C transfer error: -6 [   17.149723] Goodix-TS 1-005d: I2C transfer error: -6 [   17.207805] Goodix-TS 1-005d: I2C transfer error: -6 [   17.264307] Goodix-TS 1-005d: I2C transfer error: -6 [   17.321414] Goodix-TS 1-005d: I2C transfer error: -6 [   17.377803] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   17.387134] Goodix-TS 1-005d: I2C transfer error: -5 [   17.435815] Goodix-TS 1-005d: I2C transfer error: -6 [   17.492067] Goodix-TS 1-005d: I2C transfer error: -6 [   17.549765] Goodix-TS 1-005d: I2C transfer error: -6 [   17.608159] Goodix-TS 1-005d: I2C transfer error: -6 [   17.664246] Goodix-TS 1-005d: I2C transfer error: -6 [   17.721653] Goodix-TS 1-005d: I2C transfer error: -6 [   17.777666] Goodix-TS 1-005d: I2C transfer error: -6 [   17.834711] Goodix-TS 1-005d: I2C transfer error: -6 [   17.892267] Goodix-TS 1-005d: I2C transfer error: -6 [   17.906619] gc2145 4-003c: gc2145_write_regs: error -6: addr=fe, data=00 [   17.950693] Goodix-TS 1-005d: I2C transfer error: -6 [   18.063826] Goodix-TS 1-005d: I2C transfer error: -6 [   18.120179] Goodix-TS 1-005d: I2C transfer error: -6 [   18.177746] Goodix-TS 1-005d: I2C transfer error: -6 [   18.236103] Goodix-TS 1-005d: I2C transfer error: -6 [   18.292015] Goodix-TS 1-005d: I2C transfer error: -6 [   18.348756] Goodix-TS 1-005d: I2C transfer error: -6 [   18.405677] Goodix-TS 1-005d: I2C transfer error: -6 [   18.462949] Goodix-TS 1-005d: I2C transfer error: -6 [   18.520055] Goodix-TS 1-005d: I2C transfer error: -6 [   18.577197] Goodix-TS 1-005d: I2C transfer error: -6 [   18.633766] Goodix-TS 1-005d: I2C transfer error: -6 [   18.691075] Goodix-TS 1-005d: I2C transfer error: -6 [   18.748233] Goodix-TS 1-005d: I2C transfer error: -6 [   18.805805] Goodix-TS 1-005d: I2C transfer error: -6 [   18.862705] Goodix-TS 1-005d: I2C transfer error: -6 [   18.920089] Goodix-TS 1-005d: I2C transfer error: -6 [   18.977688] Goodix-TS 1-005d: I2C transfer error: -6 [   19.033675] Goodix-TS 1-005d: I2C transfer error: -6 [   19.092217] Goodix-TS 1-005d: I2C transfer error: -6 [   19.148146] Goodix-TS 1-005d: I2C transfer error: -6 [   19.205648] Goodix-TS 1-005d: I2C transfer error: -6 [   19.261695] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   19.271078] Goodix-TS 1-005d: I2C transfer error: -5 [   19.319719] Goodix-TS 1-005d: I2C transfer error: -6 [   19.376077] Goodix-TS 1-005d: I2C transfer error: -6 [   19.433268] Goodix-TS 1-005d: I2C transfer error: -6 [   19.547568] Goodix-TS 1-005d: I2C transfer error: -6 [   19.605672] Goodix-TS 1-005d: I2C transfer error: -6 [   19.661649] Goodix-TS 1-005d: I2C transfer error: -6 [   19.720112] Goodix-TS 1-005d: I2C transfer error: -6 [   19.777137] Goodix-TS 1-005d: I2C transfer error: -6 [   19.833698] Goodix-TS 1-005d: I2C transfer error: -6 [   19.946799] Goodix-TS 1-005d: I2C transfer error: -6 [   20.004265] Goodix-TS 1-005d: I2C transfer error: -6 [   20.061762] Goodix-TS 1-005d: I2C transfer error: -6 [   20.176135] Goodix-TS 1-005d: I2C transfer error: -6 [   20.232190] Goodix-TS 1-005d: I2C transfer error: -6 [   20.290794] Goodix-TS 1-005d: I2C transfer error: -6 [   20.348184] Goodix-TS 1-005d: I2C transfer error: -6 [   20.405109] Goodix-TS 1-005d: I2C transfer error: -6 [   20.461236] Goodix-TS 1-005d: I2C transfer error: -6 [   20.517712] Goodix-TS 1-005d: I2C transfer error: -6 [   20.574753] Goodix-TS 1-005d: I2C transfer error: -6 [   20.632173] Goodix-TS 1-005d: I2C transfer error: -6 [   20.745963] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   20.755293] Goodix-TS 1-005d: I2C transfer error: -5 [   20.860190] Goodix-TS 1-005d: I2C transfer error: -6 [   20.917670] Goodix-TS 1-005d: I2C transfer error: -6 [   20.976120] Goodix-TS 1-005d: I2C transfer error: -6 [   21.032149] Goodix-TS 1-005d: I2C transfer error: -6 [   21.089101] Goodix-TS 1-005d: I2C transfer error: -6 [   21.146746] Goodix-TS 1-005d: I2C transfer error: -6 [   21.203730] Goodix-TS 1-005d: I2C transfer error: -6 [   21.260205] Goodix-TS 1-005d: I2C transfer error: -6 [   21.317715] Goodix-TS 1-005d: I2C transfer error: -6 [   21.375781] Goodix-TS 1-005d: I2C transfer error: -6 [   21.432152] Goodix-TS 1-005d: I2C transfer error: -6 [   21.488538] Goodix-TS 1-005d: I2C transfer error: -6 [   21.545713] Goodix-TS 1-005d: I2C transfer error: -6 [   21.602720] Goodix-TS 1-005d: I2C transfer error: -6 [   21.660194] Goodix-TS 1-005d: I2C transfer error: -6 [   21.717793] Goodix-TS 1-005d: I2C transfer error: -6 [   21.831693] Goodix-TS 1-005d: I2C transfer error: -6 [   21.888233] Goodix-TS 1-005d: I2C transfer error: -6 [   21.945643] Goodix-TS 1-005d: I2C transfer error: -6 [   22.002887] Goodix-TS 1-005d: I2C transfer error: -6 [   22.022282] gc2145 4-003c: gc2145_write_regs: error -6: addr=fe, data=00 [   22.059821] Goodix-TS 1-005d: I2C transfer error: -6 [   22.116149] Goodix-TS 1-005d: I2C transfer error: -6 [   22.173660] Goodix-TS 1-005d: I2C transfer error: -6 [   22.231317] Goodix-TS 1-005d: I2C transfer error: -6 [   22.287761] Goodix-TS 1-005d: I2C transfer error: -6 [   22.345696] Goodix-TS 1-005d: I2C transfer error: -6 [   22.401734] Goodix-TS 1-005d: I2C transfer error: -6 [   22.460263] Goodix-TS 1-005d: I2C transfer error: -6 [   22.516195] Goodix-TS 1-005d: I2C transfer error: -6 [   22.530424] gc2145 4-003c: gc2145_write_regs: error -6: addr=fe, data=00 [   22.573754] Goodix-TS 1-005d: I2C transfer error: -6 [   22.688027] Goodix-TS 1-005d: I2C transfer error: -6 [   22.728287] gc2145 4-003c: gc2145_write_regs: error -6: addr=fe, data=00 [   22.745648] Goodix-TS 1-005d: I2C transfer error: -6 [   22.801635] Goodix-TS 1-005d: I2C transfer error: -6 [   22.860064] Goodix-TS 1-005d: I2C transfer error: -6 [   22.916040] Goodix-TS 1-005d: I2C transfer error: -6 [   22.928877] gc2145 4-003c: gc2145_write_regs: error -6: addr=fe, data=00 [   22.973128] Goodix-TS 1-005d: I2C transfer error: -6 [   23.031073] Goodix-TS 1-005d: I2C transfer error: -6 [   23.088205] Goodix-TS 1-005d: I2C transfer error: -6 [   23.144125] Goodix-TS 1-005d: I2C transfer error: -6 [   23.202669] Goodix-TS 1-005d: I2C transfer error: -6 [   23.258483] Goodix-TS 1-005d: I2C transfer error: -6 [   23.315664] Goodix-TS 1-005d: I2C transfer error: -6 [   23.372123] Goodix-TS 1-005d: I2C transfer error: -6 [   23.429801] Goodix-TS 1-005d: I2C transfer error: -6 [   23.486964] Goodix-TS 1-005d: I2C transfer error: -6 [   23.544103] Goodix-TS 1-005d: I2C transfer error: -6 [   23.601088] Goodix-TS 1-005d: I2C transfer error: -6 [   23.658067] Goodix-TS 1-005d: I2C transfer error: -6 [   23.715059] Goodix-TS 1-005d: I2C transfer error: -6 [   23.772287] Goodix-TS 1-005d: I2C transfer error: -6 [   23.829463] Goodix-TS 1-005d: I2C transfer error: -6 [   23.943474] Goodix-TS 1-005d: I2C transfer error: -6 [   24.000325] Goodix-TS 1-005d: I2C write end_cmd error [   24.057595] Goodix-TS 1-005d: I2C transfer error: -6 [   24.114664] Goodix-TS 1-005d: I2C transfer error: -6 [   24.171298] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x5d, flags: 0x1 [   24.180600] Goodix-TS 1-005d: I2C transfer error: -5 [   24.228948] Goodix-TS 1-005d: I2C transfer error: -6
Can someone please point me in the right direction?
Thanks all!
The errors you can see in the log from Goodix-TS is the digitizer (touch-controller). You have most likely brokken that, when stepping on the screen.
Usually it is visible as very fine cracks in the screen, when studying it closely.
You need a new screen.
(06-07-2021, 11:22 AM)Alho Wrote: The errors you can see in the log from Goodix-TS is the digitizer (touch-controller). You have most likely brokken that, when stepping on the screen.
Thank you kindly for confirming.
I still wouldn't mind upgrading my motherboard to 3GB, but the shipping costs are almost as much as the board itself to my country...
  Screen dying already? marcih 156 310,581 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 12,441 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,122 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,905 10-12-2023, 01:03 PM
Last Post: robthebold
  Microphone replacement SocialNetworkingWasAMistake 1 4,085 08-05-2022, 03:16 PM
Last Post: calinb
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,818 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,827 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,400 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 52,224 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 5,360 01-14-2022, 01:15 AM
Last Post: Uturn
