Remote desktop, video playback issues
I have the 11/29 nightly build of Mobian running on my Manjaro Pinephone, booted from a micro-SD card. Overall it's quite stable and surprisingly the phone's voice and SMS functions basically "just worked" with a Tracfone SIM for the AT&T network.
I have ssh server running on it which is great for working from the command line, but it would be nice to also be able to have remote desktop working. On my Debian desktop and laptop systems I normally run x11vnc for this, but since Mobian is using Wayland I assume something else is needed. What's the best choice?
Also I'm noticing that video playback of mp4 files is very choppy. HD videos (1080p) just show a few frames per second. I downconverted some to 480p and those work better but are still far from smooth. To get smooth playback I need to go down to 240p - VHS quality. (Actually on the small Pinephone screen it doesn't look bad!) This happens both with the default video player and VLC. Are there any tweaks that can improve this, or is it just a matter of waiting for further development? (On a related topic, where are default programs like default video player set? I'd like to make VLC the default unless there's a reason not to.)
(11-29-2020, 08:03 PM)Zebulon Walton Wrote: I have ssh server running on it which is great for working from the command line, but it would be nice to also be able to have remote desktop working. On my Debian desktop and laptop systems I normally run x11vnc for this, but since Mobian is using Wayland I assume something else is needed. What's the best choice?
From what I understand, there is a way to use x11vnc with -rawfb, but I haven't found out what the magic is just yet.
About the video stream, I use a VDR server with a USB DVB-TNT dongle. Too many frames are missing, there is a big delay between the video and the sound. I use 'mpv'. With some records get on some playback site, the sound and video are good.
With 'mpv', I use 'mpv --opengl-es=yes'.
For 'mpv' :
ayourk Wrote:From what I understand, there is a way to use x11vnc with -rawfb, but I haven't found out what the magic is just yet.
Having remote desktop working would make a lot of things easier with the Pinephone. I've managed to get X forwarding working with some applications but performance is terrible. (The X wire protocol dates to the late 1980s and it's a pig. Emulating it in Wayland probably makes matters even worse.)
This package gnome-remote-desktop in Debian buster looks like it might do the trick. It's supposed to support both X and Wayland. Mobian though looks like it's based on Debian bullseye (the upcoming Debian 11) which is still under development and I have no idea of the status of this package in that version. Haven't had time to experiment with it.
https://packages.debian.org/buster/gnome...te-desktop
https://shebangthedolphins.net/gnulinux_...sktop.html
I learned that there are 2 x11vnc type projects for Wayland:  wayvnc and waypipe
Before I got my PinePhone I thought I could just run Barrier on both devices and it would be awesome, but no go. I could not get the devices to find each other.
So I tried KDE Connect and It lacked the all important clipboard sharing functionality Sad .
I decided that being able to share the clipboard would make the lack of desktop-sharing much more tolerable.
Sidenote: I connect to my phone (ssh) on one of 3 networks USB, Wifi or WifiHotspot so I have a script, SetHostRoute.sh,  to find which network the phone is connected.
Here is my clipboard sharing script:
PasteToMobian.sh
#!/bin/bash tempFile=/tmp/tempHost.txt # Uncomment to set ssh hostname manually     # echo "ssh_hostname_here" > $tempFile # Check if the temp file created by SetHostRoute.sh exists. if [ -f "$tempFile" ]; then     # Set tempFile contents as $hostRoute     hostRoute=$(</tmp/tempHost.txt)     # Make sure SetHostRoute.sh found mobian (via usb||wifi||hotspot)     if [ $hostRoute != "notset" ]; then         # Get the clipboard         clipb="`xclip -o -sel clip`"         # Unify file path formats (file vs. file path)         clipc=${clipb/file:\/\//}         # Check if clipboard contents are a file (or a path), if so scp the file to the mobian's home directory         if [ -f  "$clipc" ]; then             scp "$clipc" $hostRoute:/home/mobian/             notify-send Clipboard2Mobian "$clipc             Copied via $hostRoute"         else         # Clipboard contents are not a file, so.. Treat as text and copy to Mobian's clipboard (using a temp file to preserve all special characters)             echo "$clipb" > ~/.clipSync.txt             ssh $hostRoute wl-copy -n < ~/.clipSync.txt &             rm ~/.clipSync.txt             notify-send Clipboard2Mobian "Text Copied via             $hostRoute"         fi     else     # SetHostRoute.sh didn't find an ssh route and printed "notset" to the tempfile.         notify-send Clipboard2Mobian "No Route to Mobian..."     fi else     # SetHostRoute.sh has yet to execute (ie. no tempFile) so.. Run it and then re-run this script.     notify-send Clipboard2Mobian "No Route to Mobian..."     /home/mj/Scripts/SetHostRoute.sh &&     sleep 5s     /home/mj/Scripts/xClipboard/PasteToMobian.sh fi
This script finds my phone on one of the 3 networks and writes the hostname to a temp file (It runs at startup or I re-run it if I switch networks):
SetRouteToMobian.sh
#!/bin/bash notify-send Clipboard2Mobian "Finding a Route to Mobian..." hostRoute="notset" echo $hostRoute > /tmp/tempHost.txt ping -q -c 1 10.66.0.1 > /dev/null if [ $? -eq 0 ]; then hostRoute="mobianusb" echo $hostRoute > /tmp/tempHost.txt notify-send Clipboard2Mobian "$hostRoute Route Set!"     else         ping -q -c 1 192.168.3.108 > /dev/null         if [ $? -eq 0 ]; then             hostRoute="mobianwifi"             echo $hostRoute > /tmp/tempHost.txt             notify-send Clipboard2Mobian "$hostRoute Route Set!"             else                 ping -q -c 1 10.42.0.1 > /dev/null                 if [ $? -eq 0 ]; then                     hostRoute="mobianhotspot"                     echo $hostRoute > /tmp/tempHost.txt                     notify-send Clipboard2Mobian "$hostRoute Route Set!"                     else                         notify-send Clipboard2Mobian "...No Route To Mobian"                 fi         fi fi
It all works just fine but I'm curious if there is a better way to do this Smile
I'm also curious to see if clipboard sharing on the pinephone exists in some other form.
If anyone is interested I'll post the script for doing the reverse and copying from Pinephone's clipboard.
Cheers!
ayourk Wrote:I learned that there are 2 x11vnc type projects for Wayland:  wayvnc and waypipe
Wayland really doesn't seem quite ready for prime time, I'm still using X on my desktop and laptop systems. I know how old and crufty X is and how ugly it is internally (I did development of X apps back in the early 1990s) but most Unix/Linux graphical programs are designed for it. I'm also used to the network transparency of X and Wayland's lack of that feature to me sticks out like a sore thumb.
Anyway, I looked into wayvnc and it is not currently available as a Debian package. However I found instructions to build from source for Debian bullseye, maybe I'll give that a try:
https://github.com/any1/wayvnc/issues/81
I'd like to get this working too.
I suppose one option is to install Gnome Shell/GDM (https://wiki.mobian-project.org/doku.php...vironments) and then just switch to a X11 session when you want to VNC?
But I'm sure there must be a way to get it working under Wayland.
Yeah, when I get some time, I'm going to look into developing the necessary Debian packages for this.
I just booted up on a mobian SD card for test purposes and built wayvnc from source using the script from the link I posted above. It works!
A few notes...
I built the program in /usr/src/wayvnc. The resulting executable is /usr/src/wayvnc/build/wayvnc. After copying this to /usr/local/bin I found that running "wayvnc" would result in missing libraries. It turns out there are libraries under build that are needed. So to do the complete job of copying wayvnc to /usr/local/bin do the following:
sudo -i cd /usr/src/wayvnc/build cp wayvnc /usr/local/bin cd subprojects/neatvnc cp -a * /usr/lib cd ../aml cp -a * /usr/lib
EDIT: I realize now I probably should have copied the libraries to /usr/local/lib instead of /usr/lib, the former being more appropriate for software installed outside the apt system. Not a big deal since it's just a handful of files but maybe I'll move them next time I boot up the Pinephone.
After doing this, everything needed to run wayvnc is in your search path. I also found that simply running wayvnc with no options didn't seem to work and found that by default it only listens to 127.0.0.1. The man page for wayvnc can be found here:
https://www.mankier.com/1/wayvnc
There are a number of options but I just used the following so it would listen to any address on port 5900:
wayvnc 0.0.0.0 5900
There are also options to add authentication and encryption and to use a config file but I haven't had time to try those out. (Might not bother since I'd only be using this on my home LAN.) More informaton here:
So now I need to just set up an easy way to launch it from the Pinephone screen.
For reference, here is the build script, it does everything and took around 10 or 15 minutes to run (I didn't time it exactly).
#!/bin/bash # Install dependencies DEBIAN_FRONTEND=noninteractive DEBCONF_NONINTERACTIVE_SEEN=true apt-get install -y \   build-essential make cmake autoconf git ninja-build meson scdoc pkg-config \   zlib1g-dev libpixman-1-dev libturbojpeg0-dev libgbm-dev \   libgnutls28-dev \   libdrm-dev libdrm-common libxkbcommon-dev libxkbcommon-tools libxkbcommon0 \   wayland-protocols waylandpp-dev wayland-scanner++ libwayland-dev set -xe # Build, copied straight from README git clone https://github.com/any1/wayvnc.git git clone https://github.com/any1/neatvnc.git git clone https://github.com/any1/aml.git mkdir wayvnc/subprojects cd wayvnc/subprojects ln -s ../../neatvnc . ln -s ../../aml . cd - mkdir neatvnc/subprojects cd neatvnc/subprojects ln -s ../../aml . cd - cd wayvnc meson build ninja -C build
  Mobian, Suspend, and Audio Playback biketool 0 2,949 12-11-2024, 12:56 AM
  desktop and lockscreen biketool 1 2,559 10-04-2024, 04:17 AM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 9,048 06-19-2023, 03:02 PM
Last Post: vusra
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 15,076 09-23-2022, 05:15 AM
  Sending Pinephone SMS from Desktop biketool 5 9,261 09-13-2022, 01:46 PM
Last Post: anonymous
  Lot of issues after flashing mobian to emmc with tow-boot benedikt55 5 8,112 08-30-2022, 01:14 PM
Last Post: benedikt55
  Telegram not as desktop app user641 0 2,407 08-05-2022, 08:45 AM
Last Post: user641
  Hardware VIdeo Acceleration on Mobian biketool 3 6,329 06-21-2022, 01:01 PM
  Working video players? jojuma 10 12,975 06-10-2022, 01:13 AM
Last Post: as365n4
  Anyone tried Signal Desktop ragreenburg 20 32,548 05-23-2022, 04:41 AM
Last Post: Anna
