USB3 SATA
Greetings,
I have a plan to use my Rock64 to host an OwnCloud/NextCloud instance.
In order to accomplish this, I would need to beef up the storage. I happen to have a spare SATA drive that is a SSD.
Would the Rock be able to power the SSD a USB3 to SATA cable or would I need an explicit power supply for it? Has anyone similar experiences or knowledge to share?
Regards,
R.T.G.
there will be no peace when they release the geese
my homepage
You might be interested in this thread, there is a lot of good info there about using sata drives with the rock64
https://forum.armbian.com/topic/5098-min...ata-cable/
I believe the rock64 usb3 port is rated at 950ma - https://forum.pine64.org/showthread.php?...4#pid29804 - I haven't used the usb3 port to power sata drives personally though.
I have a rock64 + 4 disk usb3 icybox enclosure running (externally powered) and I haven't had any problems related to the drives.
That's helpful @aog thanks. I'll try a simple usb3 powered enclosure for now. What's your icybox running, a NAS?
my homepage
  USB3 to SATA cable - Firmware Eule 0 3,503 03-03-2020, 01:31 PM
Last Post: Eule
  USB3 enough to power 2,5 external HDD? va88 11 23,079 06-06-2019, 03:40 PM
Last Post: va88
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 3,188 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  unable to switch usb3 ports on cglhu 6 13,342 05-17-2018, 08:43 AM
Last Post: cglhu
  USB 3 2.5" SATA Case thewonderer 2 6,005 12-13-2017, 06:05 PM
Last Post: thewonderer
  Best USB3.0 to SATA bridge mikedhoore 6 27,182 10-02-2017, 07:52 AM
Last Post: mikedhoore
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 5,523 09-30-2017, 06:48 AM
Last Post: dkryder
