Article: Connect PineCone BL602 to LoRa Transceiver
Here's how we transmit LoRa packets over the airwaves with PineCone BL602...
Hi lupyuen! Thanks for the article Smile
Thanks for reading [emoji846]
@lupyuen Thanks for another great article!
I am guiltily still waiting to find a time to actually hack on my PineCone Sad I intend to use your book to get started. The plan is to potentially use it as a controller for high-speed mass storage: https://forum.pine64.org/showthread.php?tid=13301
I came across this just the other day, it may be of interest: http://web.cs.ucla.edu/~omid/Papers/Hotnets19.pdf It's basically BLE rolled into WiFi, it could be interesting to investigate on the PineCone.
Thanks! That's a really interesting use case. I'll probably be stuck on LoRa for a while because to make it really useful, I need to support LoRaWAN and The Things Network. [emoji846]
@lupyuen I am becoming more and more curious about these LoRa networks, I read they are pretty cool. I have some questions if you don't mind?
1. What is the expected range in a built-up urban location? I see people quote 10km, but what could you realistically expect to see?
2. Are there some rules around how much you can use the communication? Are you expected to give way for example to allow other people to communicate?
3. If it is a mesh, do you select a target node in the network and rely on other people to relay your message?
4. Can the mesh be connected to the internet to further its range, or is it intentionally left off of the internet? For example, LoRa -> LoRa -> Internet -> LoRa - meaning you could communicate well outside the range of your mesh network?
5. Again if it's a mesh, what kind of routing protocols are being used? Is there some limitation of how many devices can be in close proximity?
6. Is there some unique ID for each device?
7. Is encryption allowed on the network, or must the traffic be unencrypted? At the very least I hope that signatures are allowed?
Any answers would be great to hear Smile
  [article] Linux Phone Takeover Juergen 4 6,766 10-08-2025, 02:31 PM
Last Post: zech.dexos
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 2 12,666 09-03-2025, 10:51 PM
Last Post: PrinceMorissette
  [Article] Creating the Unicorn Emulator for Avaota-A1 SBC (Apache NuttX RTOS) lupyuen 0 3,645 04-12-2025, 06:04 PM
Last Post: lupyuen
  [Article] Porting Apache NuttX RTOS to Avaota-A1 SBC (Allwinner A527 SoC) lupyuen 2 4,848 03-22-2025, 07:30 PM
Last Post: lupyuen
  [Article] StarPro64 EIC7700X RISC-V SBC: Maybe LLM on NPU on NuttX? lupyuen 2 5,481 03-08-2025, 09:20 PM
  [Article] Test Bot for NuttX Pull Requests ... Tested on Real Hardware (Oz64 SG2000) lupyuen 0 3,343 02-15-2025, 11:26 AM
Last Post: lupyuen
  [Article] RISC-V Emulator for Pine64 Oz64 SBC lupyuen 2 4,804 07-07-2024, 04:19 AM
Last Post: lupyuen
  [Article] Rust Apps on Ox64 BL808 RISC-V SBC and Apache NuttX RTOS lupyuen 2 4,595 07-06-2024, 06:51 PM
Last Post: lupyuen
  [Article] Coding Ox64 BL808 SBC the Drag-n-Drop Way lupyuen 3 4,690 04-02-2024, 07:38 AM
Last Post: Noahstorey
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 3,464 03-10-2024, 02:43 PM
Last Post: Must-Borrow
