Convergence dock not charging pinephone mobian
Anybody else experiencing this issue? Dock works fine for everything but it's draining my battery at a rate of about 2w. I though it might have been the usb port on my monitor i'm using it with, so I switched to a wall charger and when connected to the phone directly it charges, but as soon as I try to use it with the dock it's back to discharge mode. I'm running all the current updates on mobian at the moment.
We've got several threads on this issue. Mobian is missing patches that will permit it to charge above .5A, assuming that's the issue you are having. But it's basically unusable for anything but Ethernet w/ the screen off. There is a ticket / issue at Mobian on the matter but things haven't changed.
https://gitlab.com/mobian1/issues/-/issues/176
Maybe you can also let them know your experiences so that they know that several people would like to see these patches.
Hey,
don't know if you knew, but there's a new kernel image available which should fix most of the PD issues.
So to say the anx7688 driver finally got the latest updates... and arrived in Mobian.
Just try:
sudo apt-get install linux-image-5.11-sunxi64
Let the setup finish and reboot.
uname -a Linux mobian 5.11-sunxi64 #1 SMP PREEMPT Wed Feb 24 23:40:32 UTC 2021 aarch64 GNU/Linux
See this as well:
https://repo.mobian-project.org/pool/mai...x-sunxi64/
It's so nice to see Big Grin
Hopefully this may fix your issues as well!!!
Cheers,
scholbert
I updated to 5.11 but still see power issues with my usb hub and computer. A charging wall wart works at 1.5A though.
(03-01-2021, 04:23 PM)scholbert Wrote: Hey,
Just try:
See this as well:
Cheers,
scholbert
Thanks for the heads-up. Didn't seem to change anything here though with a few of the power supplies I've tested w/ the Convergence dock.
Yeah, thanks!
...though i seemed a little bit too optmistic.
My Apple HDMI multi adaptor still charging at 0.5A only...
Regards,
scholbert
It does report PD 2. I can't recall if it did previously. It may just need to have the current limit changed.
I do recall that Manjaro Phosh had all of this taken care of when I tested it.
The backlight does appear to flicker slightly with this kernel during discharge (while plugged in). You may need to adjust the brightness to 50%-70%  to see it.
(02-28-2021, 11:07 AM)tecnocris Wrote: Anybody else experiencing this issue? Dock works fine for everything but it's draining my battery at a rate of about 2w. I though it might have been the usb port on my monitor i'm using it with, so I switched to a wall charger and when connected to the phone directly it charges, but as soon as I try to use it with the dock it's back to discharge mode. I'm running all the current updates on mobian at the moment.
Its also because the usbc connectors contact surface is 1/16" to short.
The current operating system on your phone probably has some of the effects on the dock.
Using recent Mobian images, I have seen the charge limited to 0.5 amp on some occasions,
but at other times it says 2.0 amp...
.... this happens sometimes since our OSes are still relatively immature.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,761 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,447 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,451 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 27,953 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,683 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,347 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,642 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,515 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,360 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,214 06-29-2024, 09:36 PM
