SD card mounted to access music files unable to play
I've searched the forum as best I could to see if there was a solution.
I have Mobian installed on SD card and Manjaro Plasma Mobile on eMMC.
I have this entry in fstab to automount the SD card:
/dev/mmcblk0p2 /media/mmcblk0p2  f2fs auto,user,rw 0 0
In Manjaro:
Symlink in ~/Music to /media/mmcblk0p2/home/mobian/Music/ogg
ls -al ~/Music: drwxr-xr-x  3 kde users 4096 Feb 24 10:00 . drwx------ 20 kde users 4096 Feb 24 10:21 .. drwxr-xr-x  3 kde users 4096 Feb 24 10:00 a-ha lrwxrwxrwx  1 kde users  38 Feb 21 17:35 ogg -> /media/mmcblk0p2/home/mobian/Music/ogg
ls -al ~/Music/ogg/: drwxr-xr-x 164 kde users  8192 Jul 31  2020  . drwxr-xr-x  3 kde mobian 3488 Feb 22 07:43  .. drwxr-xr-x  3 kde users  3488 Feb 23  2020  a-ha
ls -al ~/Music/ogg/a-ha: drwxr-xr-x  3 kde users 3488 Feb 24 10:58  . drwxr-xr-x 164 kde users 8192 Jul 31  2020  .. drwxr-xr-x  2 kde users 3488 Feb 24 10:00 'Headlines And Deadlines The Hits Of a-ha'
ls -al ~/Music/ogg/a-ha/Headlines\ And\ Deadlines\ The\ Hits\ Of\ a-ha/: drwxr-xr-x 2 kde users    3488 Feb 24 10:00  . drwxr-xr-x 3 kde users    3488 Feb 24 10:58  .. -rw-r--r-- 1 kde users 5360878 Feb 24 10:00  a-ha_01-Take_On_Me.ogg
Originally file and folder ownership was mobian:mobian, changing to kde:users hasn't helped, vvave fails to even display the ogg folder.
I created a mobian group with gid 1000:
cat /etc/group: mobian:x:1000:kde,mobian users:x:985:kde,mobian
and a user mobian just in case when I had mobian:mobian ownership:
cat /etc/passwd: mobian:x:1000:1000::/home/mobian:/bin/bash kde:x:1000:985::/home/kde:/bin/bash
Both kde and mobian users have uid 1000 but kde has gid 985, mobian 1000.
Any idea what I am doing wrong? What user / group is vvave using to try and access my ogg symlink?
The pinephone 16GB eMMC is not large enough for my music files, but the a-ha folder I copied to ~/Music/ is accessible by vvave.
I tried adding uid=1000 in fstab but that doesn't work.
Thanks for your help.
(02-23-2021, 06:54 PM)dcinoz Wrote: ...
Presumably you have overwritten the bootloader on the SDcard? Or are using p-boot? Otherwise I can't understand how Manjaro is booting. If you have overwritten the bootloader then why not reformat the SDcard and mount it as ~/Music/?
I have minimal practice time on Plasma so really do not know. Or why there is a : at the end of the line for each of your examples Huh Or why Plasma has the user in a kde group - what are the permissions in ~/Music/a-ha/ ?
Both eMMC and SD card are bootable, standard installations.
I just use a script to change /extlinux/extlinux.conf to /extlinux/extlinux.conf.bak to disable SD card boot.
Then from eMMC I can toggle back to extlinux.conf so it boots back to SD card.
https://forum.pine64.org/showthread.php?tid=10634
p-boot seems neat but I've been too lazy to look into it!
I just put a : before as in this is how you do it:
Permissions are shown above.
644 / rw r r for the music files.
755 / drwxr-xr-x for directories.
I think there's a permission issue starting at /media/mmcblk0p2/ preventing 'traversal' through to home/kde/Music etc.
I had a similar issue with Wordpress / Apache on my local test web server. I just don't want to modify permissions at / for the SD card and mess everything up.
I'm hoping someone will just know.
I could create a separate ext4 partition on the SD card and it would probably work?!
I just had the Manjaro Plasma Mobile testing 20210224 update (make sure you set brightness to max, I had mine low and couldn't see thing when it rebooted, finally figured out increasing brightness via ssh did the trick).
With the latest vvave, I could add the ogg folder explicitly as a music source and it sees all the content and plays it fine,, too.
I haven't changed anything since this post, so it seems all is now good!
  Access to system directories from flatpak lagrang3 2 6,363 02-25-2025, 05:02 PM
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 2,634 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 3,807 08-22-2023, 12:22 PM
  Introducing Harborz: Lightweight Rust Music Player for Pinephone ravenblackdusk 1 3,504 08-07-2023, 12:05 AM
Last Post: ravenblackdusk
  Device memory full on multi-boot SD card Peter Gamma 4 7,111 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 8,989 08-17-2022, 03:38 AM
Last Post: shulamy
  Help wanted: location of calls and chatty data files dukla2000 3 8,903 06-13-2022, 02:01 PM
Last Post: israel
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 7,218 05-02-2022, 06:57 AM
  Writing to SD card possible with all applications? Peter Gamma 5 8,220 03-28-2022, 07:12 AM
  music making? wakyct 5 8,433 12-08-2021, 03:21 AM
Last Post: ryo
