Make King's Cross (and apps in general) fullscreen
The statusbar and titlebars of King's Cross are taking up a lot of real estate. I would say this is true of a lot of these gnome apps. Is there a way to force full screen?
yes, I use it daily !
with dconf editor assign a value, "<Alt>f" for instance, to org.gnome.wm.keybindings.toggle-fullscreen
you can then use it using the terminal layout of squeekboard
and to get more space, I set the scale to 1.5 in /usr/share/phosh/phoc.ini
you can change that at runtime with wlr-randr
(01-31-2021, 02:29 AM)fdlamotte Wrote: yes, I use it daily !
OK so I can set <Alt>f to toggle fullscreen. But for the life of me I cannot get <Alt>m (or anything) to minimise the current window. Or do we have a <Super> key in squeakboard to use the default <Super>h?
I really like the Telegram option to start minimised - it is out of sight until it has something to look at. However after opening it the first time it would be nice to get rid of it/minimise it again.
@dukla2000 if you look at phoc sourcecode there is nothing to take care of the minimize keybinding
https://salsa.debian.org/agx/phoc/-/blob...bindings.c
so unfortunatelay there seems to be no way of minimizing a window ...
(02-04-2021, 04:21 AM)fdlamotte Wrote: @dukla2000 if you look at phoc sourcecode there is nothing to take care of the minimize keybinding
thanks
Sad
  New Install, apps start but don't show up on screen?! RT3 2 3,351 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,411 01-15-2025, 08:08 PM
  Keyboard not popping up on QT apps 3x5co 1 3,327 02-08-2024, 11:45 PM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,691 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 9,243 05-04-2022, 11:45 AM
Last Post: wibble
  Apps and SD Card biketool 2 4,645 03-06-2022, 09:47 AM
  Cross compilation for Mobian nicolapcweek94 3 6,157 02-21-2022, 02:42 AM
Last Post: nicolapcweek94
  Reskinning Apps for Mobile biketool 6 8,939 12-05-2021, 02:30 PM
  no access to webdav files (for some apps) jsch 0 2,873 11-13-2021, 09:46 AM
Last Post: jsch
  How to Make Mobian Boot to Command Line Ubermunchen 4 8,063 11-02-2021, 08:34 AM
Last Post: ryo
