According to the paper that came with my second PineTime, for it to work as a smartwatch you must use GadgetBridge. I'm able to upgrade Infinitime because nRF can discover the watch easily but GadgetBridge has failed me countless times. I thought it was because I downloaded it from Google Play but the one I downloaded and installed from F-Droid doesn't work either.
Am I correct that nRF and GadgetBridge are two different types of tools but with some common features? What I'm asking is can you use one or the other? Should I be able to use the PineTime as a smart watch if it is paired with nRF? Should I be able to use the music player, etc?
The watch has Infinitime 0.9.0 and is paired with a Galaxy s8 running Android v9.
