PineCube as a Satellite Smart Speaker
Lightbulb
I was thinking that since the Cube has a speaker and microphone, it could be used as a Mycroft smart speaker, obviously since it has low specs it would use another computer for most processing, that can do the processing for multiple Cubes. It can also make use of the camera for things like barcode scanning and object detection. Is this a feasible project? And if so is this something people want?
Hi! Several prominent community contributors to the Mycroft project (lemme just toot my own horn) are working on a project that does just this. It's a superset of Mycroft called HiveMind.
It's in its infancy, to the extent that it's hardly usable, but it *will* bring Mycroft to several PinePhone distros and, by extension, other Pine devices. Indeed, the thinnest client can connect to your Mycroft instance from a Pi0. Right now, if you're a reasonably competent Linux user, you can almost certainly get a client set up on your device and hook it up to Mycroft on your computer. However, after you do that, you can only use what I'm calling "single-utterance" intents at the moment, because it can't yet ask follow-up questions or issue instructions to the device.
All of that's coming.
If you're interested in helping us along and acting as a guinea pig, you can find us in Mycroft's Mattermost server, in a channel labeled HiveMind. I cannot emphasize enough how low your expectations should be if you go there now. Your expectations for the future should be higher. We're led by the Mycroft community's most prolific dev. He's a deity around those parts.
Hello, I have activated the speaker in Armbian and I installed Raspotify and works. It has also been activated in Nixos.
Information OpenWrt image PineCube JuanEsf 14 35,769 05-04-2022, 05:53 PM
Last Post: JuanEsf
  Buildroot support for the PineCube matteo.scordino 5 13,665 04-09-2021, 08:59 AM
Last Post: Stefan_Birnbaum
  Networking unstable on PineCube with Armbian? hackkitten 1 6,490 03-14-2021, 01:07 PM
Last Post: hackkitten
  Pinecube has been added to Ambian k0m37 2 8,335 03-10-2021, 09:07 PM
Last Post: JuanEsf
