Proximity sensor rubber pad gasket replacement
My braveheart pinephone never had the small gasket that covers the proximity sensor. This causes the proximity sensor to provide bad readings to phosh and blanks the screen. Now after making a phosh based image I edit the udev rules to disable the proximity sensor. I was hoping the replacement mainboard would include the proximity sensor cover, but it did not. Though an uncommon problem I'm not the only one to have this issue based on the various messages on the forum.
I tried the fix shown by RWXYZ, but I'm having trouble getting the tiny pieces aligned correctly. See https://forum.pine64.org/showthread.php?...=proximity
Does anyone have a 3D printable fix for the proximity and light sensor gasket? I might be able to get a friend to print it some versions.
Any other thoughts on potential fixes? I'm missing the part so don't know exactly what is needed.
It's a rectangular rubber block with holes that line up with the windows, and fits in the recess in the front panel. You can see it in https://www.youtube.com/watch?v=J3AJEF7akkw - the second part of the video is dedicated to it.
Why not have Pine64 send you one if they failed to provide it? They left a part out of my phone and were eventually persuaded to send it to me.
(12-12-2020, 08:50 AM)puffchumpy Wrote: My braveheart pinephone never had the small gasket that covers the proximity sensor. This causes the proximity sensor to provide bad readings to phosh and blanks the screen. Now after making a phosh based image I edit the udev rules to disable the proximity sensor. I was hoping the replacement mainboard would include the proximity sensor cover, but it did not. Though an uncommon problem I'm not the only one to have this issue based on the various messages on the forum.
I just had my phones in pieces and took some very amateur photos of mine in the jaws of my micrometer, yell if you really are clutching at straws and can cope with awful pics!
Actually considering I let the magic smoke out of 1 of my USB daughter boards could loan you 1 for a couple of weeks if you are in the UK? (Actually the antenna male came off the board with the cable when trying to unplug the antenna cable :-(  )
(12-13-2020, 02:35 PM)dukla2000 Wrote: I just had my phones in pieces and took some very amateur photos of mine in the jaws of my micrometer, yell if you really are clutching at straws and can cope with awful pics!
@dukla2000, Thank you for the loan offer but I'm in the USA. The "very amateur photos of mine in the jaws of my micrometer" might be very helpful. Any measurements or dimension might help me improvise a replacement part.
@wibble , I reviewed the mainboard replacement video again. You are correct that they zoom in on the component. I took a screenshot of the proximity cover from the video:
[Image: ProximitySensorCover.png]
The piece is so small that making a replacement part is hard. I don't really have tools to work at that size. Perhaps drilling tiny holes in something rubbery and then cutting to size will work.
BraveHeart edition should already have the light sensor gasket. Please PM me your shipping address and I will send one to you.
(12-15-2020, 02:48 AM)tllim Wrote: BraveHeart edition should already have the light sensor gasket. Please PM me your shipping address and I will send one to you.
Dear @tllim
What about customers, who still can't brought a pinephone(hello from Russia), but have assembled phone from spare parts?
My spare parts complect have no earpiece, loudspeaker and this rubber pad. I found compatible speakers and install it, but rubber pad I can't find. Can you help me too, please?
(12-14-2020, 04:51 PM)puffchumpy Wrote: ...
OK - attached below. I have shrunk them to 800*600, the originals are 4000*3000 (2-3MB each) - drop me a pm with an email address if you want those.
(12-15-2020, 01:12 PM)dukla2000 Wrote: OK - attached below. I have shrunk them to 800*600, the originals are 4000*3000 (2-3MB each) - drop me a pm with an email address if you want those.
I think the height measurement will be very useful. PM'd you to ask for the originals.
Dear @tllim
You are not suppose to assembly Pinephone from spare parts. This is not the original intent of spare parts usage.
I can send one rubber light sensor gasket to you, just PM me your address.
  Screen Replacement Instructions erikkugel 5 12,483 02-24-2025, 06:55 AM
Last Post: anonymous
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,929 10-12-2023, 01:03 PM
Last Post: robthebold
  Microphone replacement SocialNetworkingWasAMistake 1 4,098 08-05-2022, 03:16 PM
Last Post: calinb
  Screen replacement Csanderson0313 4 7,556 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 30,492 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 4,806 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 12,803 08-29-2021, 07:03 AM
Last Post: bcnaz
  inner earpiece speaker replacement dcinoz 4 9,202 07-24-2021, 04:37 AM
Last Post: dcinoz
  Screen or motherboard replacement? Static Face 2 5,867 06-08-2021, 12:57 AM
Last Post: Static Face
  Mainboard replacement does not boot/charge boarf 2 5,603 05-02-2021, 10:47 AM
Last Post: boarf
