RS-485 CAN HAT Rock won’t boot
I need to talk to an RS-485 buss
I purchased a RS485 CAN HAT for Raspberry Pi 4B/3B+/3B/2B/B+/A+/Zero/Zero W/WH,Allow Long-Distance Communication via RS485/CAN Function Onboard CAN Controller MCP2515 via SPI Interface Transceiver SN65HVD230
https://www.waveshare.com/wiki/RS485_CAN_HAT
When I install the header my rock won’t boot
Armbian 20.08.17 Buster with Linux 4.4.213-rockchip64
Any ideas?
Did you managed to get your HAT working?
I have a similar issue with a dAISy HAT which comunicates through the serial pins with the board, as soon as the HAT is on, the Rock64 won't boot.
Which is similar in behavior as described in the pinned Rock64 Boot-up Bug with Serial Console Cable thread.
Luckily for me the HAT needs only 3.3V and Rx/Tx so I may have to use a cheap USB to serial adapter to get my HAT working with the Rock64.
It's a shame that we can't use a HAT made for RaspberryPi and plug it straight onto a Rock64 and expect it to work. Confused
  Help! Rock64 won't boot anything! trohn_javolta 3 10,691 03-09-2020, 06:03 PM
  Boot from M.2/USB 3 Max_H 8 17,840 05-03-2019, 02:56 AM
Last Post: Monstercrunch
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,524 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 5,171 11-26-2018, 11:45 PM
Last Post: evilbunny
  ROCK 64 board unresponsive S265 1 4,551 08-05-2018, 06:51 AM
Last Post: paradise
  can a SD card be used as storage with emmc boot Enzo 9 22,585 05-10-2018, 08:53 PM
Last Post: pfeerick
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 10,556 04-13-2018, 03:45 AM
Last Post: Z80
  Video camera for Rock 64? Bapple 4 10,731 03-05-2018, 09:03 PM
  SOC getting very hot; no boot. dtkenmo 1 5,090 02-20-2018, 10:19 PM
