Need help with extra info to resize partition in EMMC
I am new here (and gald to be here). I have the postmarketOS edition, and I would like to flash the EMMC with the last Arch image.
I have the Jump Drive on a SD card and I can boot from it. Also no problem to expose the EMMC drive in my Linux laptop.
Until there all good, but then I become confuse and wnat to be sure I won't make an error :
The wiki instructions says to run cfdisk to resize the partition., this is OK. But I am not sure WHICH partition to resize ?
I can see 2 partitions, the small boot one and a other bigger (Lucks encrypted)
[Moderator edit: Removed image that did not display properly]
Sorry if the question was already answered (could not find it) and sorry for what may be a noob question.....
Do I need to resize (from the image above) sdg1 or sdg2 ? And to be 100% sure.... Must it be ext2 ? Can it be ext 4 ?
Thanks in advance for any help !
Just flash to EMMC using dd or Etcher or whatever. No need to resize. Arch does that. You'll lose the encryption though.
(10-26-2020, 06:44 AM)Veraendert Wrote: Just flash to EMMC using dd or Etcher or whatever. No need to resize. Arch does that. You'll lose the encryption though.
Thanks, I'll do this . (And sorry for the big jibbrish text in the OP, seems I didn't past the image the right way)
Pas de problème
  Ordered PinePhone till today have no info or confirmation about order hennadiyt 1 2,407 10-05-2024, 02:20 PM
  install iso from sd card to emmc aular 2 4,125 03-11-2024, 10:24 PM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 6,663 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 7,355 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 5,810 04-13-2023, 05:55 AM
  This is how you flash to eMMC easily Luke 49 156,060 12-25-2022, 05:13 PM
Last Post: fxc
  emmc formatted by mistake (it no longer appears) elode 5 8,720 07-12-2022, 04:33 AM
Last Post: elode
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 4,067 05-31-2022, 04:26 PM
Last Post: fxc
  no emmc after flash ragele 3 5,972 05-30-2022, 04:26 AM
Last Post: fxc
  eMMC label gilwood 1 4,722 12-31-2021, 06:25 PM
Last Post: moonwalkers
