masquerading and truncated sms; mis-patched phone calls
Bug
Some time in September I called someone I had spoken to two, three times prior. This time a different person answered. It took a few second before I realized it.  I double checked afterwards. It did not show that I dialed the 2nd person.  Same day, similar situation, the phone call went to the voicemail of yet another friend of mine whom i did not intend to call.
The above happened in one day. Hasn't happened again since.
Today, it was with sms. I received a sms that was clearly from my sister, but it came under a friend whom i hadn't been texting since 2 days ago. When I double checked with my sister, I found that I received 2/3 of her text, and the end of the text I received was not from her. Nor was it from the friend.
Any insights?
Happened once a few weeks back,  replied to one Son's text and a different Son received the reply.
But it has not happened since then.
That happened on Simple Mobile (T-Mobile reseller)
I wonder if that could possibly be a carrier/network issue, rather than a operating system error  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
"I wonder if that could possibly be a carrier/network issue, rather than a operating system error ?."
I think you might be right. I am also on a T Mobile network.
  Calls 4G not working oliwierzgorniak 2 5,769 08-06-2024, 02:20 PM
Last Post: baptx
  No audio on calls after updating today Zebulon Walton 10 16,055 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  phone does not ring (when sleeping) jsch 2 4,893 10-07-2022, 08:08 AM
Last Post: alaraajavamma
  MATE on pine phone user641 6 9,706 05-05-2022, 09:44 AM
  Chrony interrupts calls. jhasler 0 2,286 04-18-2022, 08:48 PM
Last Post: jhasler
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,734 02-18-2022, 08:54 AM
Last Post: battlegarden
  Phone mic isn't working at all D347h 2 4,714 01-26-2022, 07:34 AM
Last Post: D347h
  Calls : two rings and call cut and restore. Gribouille 0 2,287 01-14-2022, 07:40 AM
Last Post: Gribouille
  Screen/display gets switched on by itself / Phone wakes up from suspend Anna 5 9,429 01-04-2022, 01:24 PM
Last Post: pothos
  Block Phone Numbers? MarkF 6 10,660 12-02-2021, 08:26 AM
Last Post: Smeegle
