Flash size?
I haven't seen this mentioned yet, apologies if it has been answered.
I used win32 disk imager and the latest Android image on a 32 GB card.  The system runs like a dream, but only reports 4 GB of usable space (it detects 32 GB of flash, interestingly).
So I popped the card back in my reader on my pc and noticed that the disk has 3 partitions--I'm guessing a small boot partition, the android partition, and the usable flash.  The remaining 20+ GB are simply unpartitioned.
How do I gain access to that extra space?
(05-01-2016, 09:14 PM)jcdoe Wrote: I haven't seen this mentioned yet, apologies if it has been answered.
Sounds like you used a dd image. If you can use the Phoenix tool and its image it will utilize the whole flash. It is not always easy but...
I read that when using the dd image, the first boot takes longer due to the fact that of converting FAT32 into the EXT3 format that android uses. The PheonixCard utility takes this matter into account.
where do people come up with thus stuff...
  Reducing Android Image download size. KPhillisJr 4 13,171 08-21-2017, 04:48 AM
Last Post: winstongel
  android image & sd card size problems tomarneson 11 27,793 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 19,001 12-20-2016, 08:17 AM
Last Post: Bluphire
  MicroSD Size mismatch with Image Hbtr 23 47,160 08-31-2016, 09:00 AM
Last Post: montero65
  U-Boot, partition layout and flash kap1r0t0 13 24,474 06-02-2016, 12:31 PM
Last Post: kap1r0t0
