USB cable to power device
(02-26-2016, 01:19 PM)Ghost Wrote:
(02-26-2016, 01:03 PM)Ron Piggott Wrote: What is the USB cable that I need to power the Pine64?  Is it a USB mini?  Ron
Micro USB, connected to a 5 volt 2 amp power source.
Hi im kinda new ro this.
What will be the effexts of using a 3 amp power source?
Because i have the intention of plug in a hard drive to the pine, so i dont know if 2 amps will be enough.
Or do u recomend using a port multiplier with its own power source? ¿
Thanks in advance
Hello Smile
Just a little piece of advice - it's best to buy thick - e.g. 20AWG - cables. Even if you have the right power supply thin cables can, potentially, cause problems (particularly under load). I might add that things get worse the longer the cable is - so if you require a long cable its safe to go with 20AWG.
For a technical exploitation of why this is the case please see: http://goughlui.com/2014/10/01/usb-cable...ging-slow/
Hope this helps!
If you're going to build a cluster you might consider re-purposing a PC power supply or using a single high amperage power supply to power it rather than a collection of wall pods, this will allow you to customize the power set up and add control.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,568 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 39,013 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,636 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,766 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,599 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 11,227 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 53,385 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,903 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,763 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 58,347 10-05-2016, 06:43 AM
Last Post: Ghost
