What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#81
(07-26-2020, 06:04 AM)devrtz Wrote: OP updated
It should now work again with the flashable binaries (as before)
and as a debian package without prompting every time for an upgrade to debians u-boot.
Thanks!
Thanks for these, devrtz.
I was having random phosh crashes as well and flashed the 624 MHz version, which is working pretty well -- I still get the occasional hang up, but it is less common and seems to resolve faster.
However, I'm confused as to whether the clock speed was really my problem, since this post suggests the default when I flashed my OS (a couple days ago) was already 552 MHz. Is this correct? Is your 552 package the same as the default, or is it still different somehow?
Thanks for any clarification.
As the other post mentions: Mobian is running on 552MHz so it seems weird to me if you're phone is running more stable with the higher clocks. My 552 package is the same as what mobian ships with (well the version string is different, but that's it).
Well, I can almost definitely say, 552 now works for my phone after all the power optimizations with no crashes. Even though my phone would previously crash at anything above 492. However, the standard 624 still being pushed definitely crashes my phone hard.
Gonna play with going up in speed to see if it can go even higher than 552 stably. Thanks for the help @devrtz
According to the A64 documentation, it supports 667MHz LPDDR3-1333 RAM. I wonder what is causing the problem.
(08-16-2020, 03:31 PM)amosbatto Wrote: According to the A64 documentation, it supports 667MHz  LPDDR3-1333 RAM. I wonder what is causing the problem.
The A64 datasheet stated supports PC-1333 DDR3, NOT LPDDR3 !
So what's the best for PP CE?
PBP ISO / Debian Bullseye (unofficial installer)
So it looks like I can get away with 576 without crashes, but it feels like some things are slower than they are with 552, so I think I'm getting near the limit of my RAM's stability, I still might go up again to see it I can get anymore and find the new actual crash line.
According to the A64 datasheet (p.7):
Quote:SDRAM
Compatible with JEDEC standard DDR2/DDR3 /DDR3L/LPDDR2/LPDDR3 SDRAM
•Support clock frequency up to 667MHz(DDR3-1333)
Does Allwinner provide any specs on what is its max clock for LPDDR3? If not, should we assume that 624MHz is going to be the max speed possible for the LPDDR3 RAM?
Well, 588 seems to be the absolute line for me, so I guess for "not riding the edge" stability I'll stick with 576. It also seems that the u-boot people have dropped things back to 552 from here on because of the stability issues, which is good. Though there are some regressions with the update, so testing isn't going well (at least with manjaro).
I hope you keep up the testing @devrtz for the people who want the extra performance and can pull it off though. It is rather noticeable performance if you can turn up the speed. That or the u-boot team start to keep a couple overclock versions as well like the Arch team are doing.
Thanks again for all your help with this pesky issue!
  emmc speed via usb? joe1 0 3,195 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 9,839 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 10,577 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 11,005 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 10,929 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 8,163 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 10,320 06-22-2020, 09:20 AM
Last Post: Nooblife
