Segfault with GCC in Armbian [Solved].
To continue this story of over and under clocking memory for stability.  Here is a graph showing the relative memory bandwidth of the Rock64  with different memory clock speeds.
[Image: rock64_400.svg]
Again both of the Rock64 single-board computers I have seem stable with the memory clock set to 400 MHz. Since the errors at 786 MHz are intermittent, my guess is the memory could still go a little faster, perhaps 600 MHz or even 666 MHz.
Does anyone know how to make uboot files which initialize the memory at 600 or 666 MHz?
I don't. But I do thank you ejolson for delving into this issue some of us have. Our boards should have been replaced free imo but this thread may offer us hope in getting ours /mine to compile pkgs properly. Some care about other uses like a smooth desktop, games, video and this would help them too. I'll test whatever you get done just leave us instruction steps please.
i have just successfully created my own custom ddr.bin with 666mhz mem freq following the idea from here:
  https://forum.libreelec.tv/thread/10140-...post132388
by simply changing the freq values in the ddr.bin with a hex editor - in my case i used it for a rk3328 tv box,
but i think it will work the same way for the rock64 too ... here are my notes about it:
  https://github.com/hexdump0815/u-boot-mi...mhz.readme
good luck and best wishes - hexdump
This is a followup post to to confirm that the Rock64 board that was experiencing segmentation faults with the default 786 MHz memory clock on Armbian is now stable with the uboot-initialized 333 MHz setting.
On a selection of computational benchmarks performance is about 77 percent of the original setting;
for compilations with gcc more than 80 percent of the original performance is retained with the added advantage that the system doesn't crash and the compiler doesn't create segmentation faults.
I understand, but did not verify, that setting the memory clocks to 333 MHz has a noticeable affect on video playback.
As far as I'm concerned this problem is solved and I'll try to mark it as such. Although one out of the two Rock64 single-board computers I have required this configuration change, based on posts appearing on this forum, my suspicion is a much less than 50 percent--perhaps closer to 10 or 20 percent--of systems in use actually exhibit this problem.
Even so, I would favor a note on the wiki support page for the Rock64 explaining how to work around system instability by reducing the DDR RAM memory clock.
______________________
Optics 4 birding
  Rock64 No Audio - Solved wbecks 12 50,700 08-13-2021, 01:23 PM
Last Post: blakeadam
  Rock64-4gb,Armbian Debian Stretch: Plex, Radarr, NZBGet and Sickchill WOW Baracuda2 1 5,261 02-27-2019, 03:34 PM
Last Post: Luke
  [SOLVED] stuck at emmc dr_dre 10 23,582 04-29-2018, 05:10 PM
Last Post: pfeerick
  Solved - When did you order your Rock64 rhille 5 11,550 08-25-2017, 07:17 AM
Last Post: rhille
