Disc Image File when extracting....
Hi-
I am only seeing a disc image file when extracting the phoenix card and the actual Android 5.1.1. Any ideas?
Thanks.
(04-29-2016, 06:57 PM)reed2hooah Wrote: Hi-
Thanks.
Not exactly sure what you mean, but you use the PhoenixCard software to burn that Android disc image to a micro sd card.
The Android file is supposed to be a disc image.
The PhoenixCard software is an executable application.
Instructions for burning images can be found on the Pine64 wiki page, here.
  Soquartz - what image for Model A baseboard? kbanfield 0 2,980 10-14-2022, 10:38 AM
Last Post: kbanfield
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 208,637 01-15-2020, 12:46 PM
  Creating bootable Debian backup image Drago 3 9,420 12-11-2018, 03:42 PM
Last Post: evilbunny
  Boots just fine. Can not install new image. willpine 5 11,634 07-25-2017, 06:39 AM
Last Post: willpine
  unable to write an pine64 image on a 16G micro suresh 2 8,254 01-26-2017, 12:56 PM
Last Post: suresh
  Can't make the Android image boot Passiday 3 8,548 10-07-2016, 09:34 AM
Last Post: Passiday
  No IMG file after extracting Android dd tomwjr 15 32,983 08-12-2016, 03:53 PM
Last Post: tomwjr
  Image Burn Issue and Power Auto Off Issue Mohit B 3 9,342 08-02-2016, 09:35 AM
Last Post: MarkHaysHarris777
Exclamation recurring blank screen on A64+ with ubuntu image & any desktop gui faddah 5 11,025 06-15-2016, 10:55 AM
Last Post: jl_678
  Wired distorted boot image Cestrefeld 16 33,107 05-29-2016, 05:00 PM
Last Post: edu2004eu
