Remix OS DD image
#21
(04-01-2016, 10:57 PM)ML-Anderal Wrote: Here is a DD image for Remix OS for now.
1. You will need to have a MicroSD card at least 8GB
2. If you have a larger MicroSD you will need to extend Partition 1 to the rest of your drive size.
If you have any questions let me know. You should be fine to use Win32.
Please let me know if this image fixes the restarting issue I know a lot of you are having. Thanks!
https://drive.google.com/open?id=0BwrRh3...UN2VndCVTQ
The Pyramid method didn't work for me so I did DD and it worked fine.  After booting for the first time and checking it all out I turned it off and went back in Windows with the 64 gb SD card to extend the partition.  In Disk Management it looked like it worked just fine but when I went back into Remix it still shows the card as being under 8gb.
Any ideas for how to fix that?  Thanks.
Edit- I just saw the post on the last page so I'll try that. Disk Management didn't show all those partitions though so I guess I'll try a different program.
No luck at all with the partitioning on Windows or on my Android entertainment center box.  I have a Mac as well.  Is it something I can do in the command line?  Also, Windows only gave me the option of Fat32 and ExFat (or NTFS, I can't remember) when I originally formatted it.  Is that causing any issues?
(04-28-2016, 10:47 AM)mrjohnnycake Wrote: No luck at all with the partitioning on Windows or on my Android entertainment center box.  I have a Mac as well.  Is it something I can do in the command line?  Also, Windows only gave me the option of Fat32 and ExFat (or NTFS, I can't remember) when I originally formatted it.  Is that causing any issues?
I can create a 64GB DD image and zipped for you to try out.
That would be great.  I'm not sure how long it takes to do that with each release but if it's not too big of a dead it would be good to have different DD download options for each drive size.
Thanks.  I really appreciate it.
64GB Remix 2.0 DD image already available on Pine64 wiki page.
The only images I have gotten to work so far have been from you Anderal, thanks! I'm on a 2gb board so I'm running into the ethernet/rebooting issue with any Android/RemixOs image I run, but the Ubuntu image worked, it just didn't play well with a lot of my media collection, so I'm hoping an updated Remix image comes along soon that fixes the ethernet issue.
(04-30-2016, 11:16 PM)KillrKowalski Wrote: The only images I have gotten to work so far have been from you Anderal, thanks! I'm on a 2gb board so I'm running into the ethernet/rebooting issue with any Android/RemixOs image I run, but the Ubuntu image worked, it just didn't play well with a lot of my media collection, so I'm hoping an updated Remix image comes along soon that fixes the ethernet issue.
Already feedback the Ethernet issue concern to Remix team.
  sourround sound - Remix MrSarkasmus 0 5,168 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 64,266 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 7,055 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 252,302 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,574 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,362 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,646 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,839 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,471 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,661 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
