Unable create libertine container
I received my pine64 ubsports edition today. I was able to work on the phone without a problem. I am having problems creating container to run linux applications, every time exit with error 1 and delete the container.  I am not able to do it from the configuration tab I tried from the terminal.  I reset the phone a few times from the system configuration screen.
I think the os is broken, how can reset it to factory default?
Regards,
Al
I don't think anyone has got libertine to work fully on the pinephone yet. The current sticking point seems to be the display.
https://forum.pine64.org/showthread.php?...=libertine
(07-24-2020, 08:47 AM)wibble Wrote: I don't think anyone has got libertine to work fully on the pinephone yet. The current sticking point seems to be the display.
I was able to create a container initially and installed ssh and Firefox but failed to run I destroyed it and try to create an lxc one but I was getting a message that lxc was not installed so I remount the fs with r/w and installed lxc and lxd also , I updade and upgrade it. I tried to create new container and failed Everytime. I haf reset the phone from the configuration option without a success.  Hiw can reset to factory defaults, this phone is ubports edition.
Do I have to boot from sd card and transfer to the emmc?
Regards
That's probably the easiest way. Details in the wiki:
https://wiki.pine64.org/index.php?title=..._Jumpdrive
  Device Unable To Read MicroSD Card _radv_ 19 20,589 02-18-2023, 02:01 PM
Last Post: _radv_
  Cannot even create profile because screen won't rotate2 absolutenoob 5 8,237 02-28-2022, 01:00 PM
Last Post: Jetpac
  Cannot Create Profile - Cannot even Flash OS absolutenoob 6 11,663 12-17-2021, 03:52 AM
Last Post: guenther
  unable to install any software pine-user1 2 3,789 11-09-2021, 01:07 AM
Last Post: ryo
  Unable to get PinePhone Manjaro - Arm to Update kmk7x 1 5,805 03-02-2021, 05:56 PM
  I am stuck, When in Terminal, unable to enter a password Whio84 3 6,334 02-12-2021, 03:46 PM
Last Post: Whio84
  Unable to read sd card bmeinka 9 15,583 02-10-2021, 11:25 AM
Last Post: Alfiory
