$HOME variable over SSH
Hello everone,
I just booted postmarketOS from my SD card and logged into it over SSH. I noticed that
cd ~
takes me to /root and not to /home/user. Is there a reason for that and can it be changed? I tried
usermod -d /home/user user
but it only said
usermod: no changes
What user are you logged in as?
$ whoami
What shell are you running?
$ ps
What does /etc/passwd list as user's home directory? (Second-to-last field)
My first guess is you're getting logged in as root since nobody else should have /root set as their home directory.
(06-26-2020, 02:45 PM)Dendrocalamus64 Wrote: My first guess is you're getting logged in as root since nobody else should have /root set as their home directory.
Sounds like this is it really. `cd ~` definitely brings me to my home directory and the only real explanation would be executing that command as root.
Thank you for your replies. I don't remember which user it was but have not had an issue with it anymore. Thank you
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 10,938 05-28-2023, 10:54 PM
Last Post: Avisando
  Adding a program to home screen. pcdoodle 1 5,497 08-12-2020, 12:02 AM
Last Post: Boern
