Any Progress on the new update for Remix OS?
#81
(04-22-2016, 10:02 AM)Luke Wrote:
(04-22-2016, 01:56 AM)King Patte Wrote:
(04-21-2016, 02:10 PM)marshmel Wrote:
(04-21-2016, 01:58 PM)Rhymoore Wrote: Anyone else got a problem with communicating with google servers? It suggests retrying it again... i did.
at least the ethernet bug is gone, but i can't do much on my 32gb pine 64 with 2gb ram and the new os version, when i can't log into my google account^^
i am on a 100mbit ethernet hub, the pine is a trusted device in my router (fritz.box) so there shouldn't be any issues anymore, except there is another problem now with (maybe) google certification?
A wild maybe unhelpful stab in the dark, Is you Time and date and time zone set correctly? I've not had this issue so can't be sure  Huh
(04-21-2016, 12:43 PM)King Patte Wrote:
(04-21-2016, 09:39 AM)janjwerner Wrote: DD image:
for 64gb card:
https://drive.google.com/file/d/0B_6QLyX...sp=sharing
for 32gb card:
Do i need this size of Card for this? Or can i use a 16GB Card?
Yes you need that size card. But you can shrink the size of the Image using http://softwarebakery.com/shrinking-images-on-linux
 If you really want too.
I tried the DD image for 32gb card. And it does not boot at all. I think that there is a Error with the img File. Its just 881 MB. The others had a Size of 7GB.
So I too had no luck with getting the img to work, but suspect the problem might be with my SD card (which reads 31GB). I have ordered a new one and will try tomorrow and report back Smile
Good luck Luke  Confused
(04-21-2016, 12:43 PM)King Patte Wrote: Do i need this size of Card for this? Or can i use a 16GB Card?
Thanks, will report in soon !
(04-21-2016, 02:10 PM)marshmel Wrote: A wild maybe unhelpful stab in the dark, Is you Time and date and time zone set correctly? I've not had this issue so can't be sure  Huh
What kind of SD card writer are you using? I found that using a USB 2 Card writer was the only way I could burn the Phoenix Image.
(04-22-2016, 01:56 AM)King Patte Wrote: I tried the DD image for 32gb card. And it does not boot at all. I think that there is a Error with the img File. Its just 881 MB. The others had a Size of 7GB.
Hey, I tried everything. USB card reader/writer, inbuilt macbook reader/writer, my epson printer card reader .... I tried burning the img from Linux, Win10 and OSX ... I tried 3 different cards (even bought a new one just to be on the safe side). And nope, nothing. I might add that I've had no problem with burning the Arch and Ubuntu imgs ... Something is not right.
(04-22-2016, 10:02 AM)Luke Wrote: So I too had no luck with getting the img to work, but suspect the problem might be with my SD card (which reads 31GB). I have ordered a new one and will try tomorrow and report back Smile
Waw you really have tried everything. Today and tomorrow ill try and build you an Image. and confirm it works, then ill upload it to you. Im a bit busy today cooking dinner for my family. But ill get back to you as soon as I can.
(04-22-2016, 01:10 PM)marshmel Wrote: Good luck Luke  Confused
That is very kind of you. No need to hurry my friend, this is not an urgent matter. What you cooking ? - I am making my wife tortillas today as a surprise Smile
(04-24-2016, 09:07 AM)Luke Wrote:
(04-24-2016, 07:19 AM)marshmel Wrote: Im a bit busy today cooking dinner for my family. But ill get back to you as soon as I can.
Maybe we could all exchange cooking recipes in the meantime while waiting for all boot loops and burning images to get solved? [emoji3]
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
(04-22-2016, 06:17 PM)Luke Wrote: Thanks, will report in soon !
OK done and I can confirm it works. Its a large 8gb download I not used compression didnt want any corruptions. Use Win32disk imager To write the Image. I used windows 10. GOODLUCK!!!!!!!
https://drive.google.com/file/d/0Bysw810...sp=sharing
Im cooking roast pork with crackling Smile
And you need at least an 8gb SD card
(04-24-2016, 04:06 AM)marshmel Wrote: What kind of SD card writer are you using? I found that using a USB 2 Card writer was the only way I could burn the Phoenix Image.
Roast pork!? wow, fancy stuff... Thank you for the img. I now have 3 32gb cards on my desk - dont think it will be a problem Wink Will give it a spin right away.
(04-24-2016, 06:28 AM)Luke Wrote: Hey, I tried everything. USB card reader/writer, inbuilt macbook reader/writer, my epson printer card reader .... I tried burning the img from Linux, Win10 and OSX ... I tried 3 different cards (even bought a new one just to be on the safe side). And nope, nothing. I might add that I've had no problem with burning the Arch and Ubuntu imgs ... Something is not right.
I really hope it works for you mate. Let me know cheers Smile
  sourround sound - Remix MrSarkasmus 0 5,168 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 64,266 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 7,055 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 252,302 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,574 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,362 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,646 04-17-2017, 04:20 AM
Last Post: simplexdan
  Update Feature not working on 2.0 2016071801 Jaylc 0 4,617 02-28-2017, 06:50 PM
Last Post: Jaylc
  Stuck at Remix OS logo leongzhi 9 33,839 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,471 12-19-2016, 07:49 PM
Last Post: Toriless
