Software options for thermal throttling?
Are there any daemons, kernel tweaks, ... available to have more aggressive thermal throttling on the PinePhone? It does get very hot if running demanding tasks, and I don't like it both for my hands as well as the possible impact on battery lifetime. However, making sure to limit all tasks one by one is lots of work, it'd be nicer if the whole system just throttled earlier when temperature crosses a certain threshold over a certain amount of time.
Does somebody happen to know if some throttling tweaks like that are available in the kernel or in some power management daemon that can be tweaked for use on the PinePhone? Or would any of you know a good place to request this for consideration?
Away
(06-09-2020, 09:59 PM)e1337 Wrote: Are there any daemons, kernel tweaks, ... available to have more aggressive thermal throttling on the PinePhone? It does get very hot if running demanding tasks, and I don't like it both for my hands as well as the possible impact on battery lifetime. However, making sure to limit all tasks one by one is lots of work, it'd be nicer if the whole system just throttled earlier when temperature crosses a certain threshold over a certain amount of time.
I don't own a PinePhone but I assume the kernel includes the thermal subsystem.
This would reduce the cpu frequencies to make sure the CPU temperature does not cross 55C. That works on my Pinebook Pro
# echo 55000 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_0_temp
You can check the current temperature
$ cat /sys/devices/virtual/thermal/thermal_zone0/temp 35000
Here you can check what each termal_zoneX represents and throttle other blocks as well
$  cat /sys/devices/virtual/thermal/thermal_zone?/type cpu gpu
That sounds super promising! Sadly, there seems to be some issue with the sensors:
$ sudo cat /sys/devices/virtual/thermal/thermal_zone0/temp cat: read error: Invalid argument $ sudo cat /sys/devices/virtual/thermal/thermal_zone1/temp cat: read error: Invalid argument $ sudo cat /sys/devices/virtual/thermal/thermal_zone2/temp cat: read error: Invalid argument
Is this maybe why the device runs so hot? Is this normal...?
Away
(06-10-2020, 12:27 AM)e1337 Wrote: That sounds super promising! Sadly, there seems to be some issue with the sensors:
I don't have a PinePhone and can't help you further. You are on your own. What I would do:
1. learn your thermal settings
$ zgrep -i thermal /proc/config.gz
2. understand what these settings mean (and look for interesting settings not in your kernel)
https://elixir.bootlin.com/linux/latest/...al/Kconfig
3. understand the thermal driver's sysfs api (I don't understand why this file vanished from recent kernels) and see how to throttle
https://elixir.bootlin.com/linux/v5.2.21...fs-api.txt
(06-10-2020, 01:08 AM)Der Geist der Maschine Wrote: I don't have a PinePhone and can't help you further. You are on your own.
I wasn't necessarily asking you since I think devs frequent here, so I would assume someone might know: If anyone knows why the temperature sensor doesn't want to work, feel free to jump into the conversation Wink
Away
A little bird told me it is supported standard (/fixed) in 5.7 kernel. So I am anxiously awaiting a new release with a 5.7 kernel Big Grin
  Pinephone software Csanderson0313 3 2,336 07-10-2026, 02:21 PM
  "Repository" for Safe Software/Apps? MarsColonist 2 4,371 05-12-2022, 06:29 PM
Last Post: MarsColonist
  Favorite software? Scary Guy 0 2,268 02-16-2022, 01:28 PM
Last Post: Scary Guy
  unable to install any software pine-user1 2 3,859 11-09-2021, 01:07 AM
Last Post: ryo
  software jesica 3 6,361 10-30-2021, 08:27 AM
Last Post: beta-user
  jumpdrive software might be faulty (or my pinephone hardware) zetabeta 3 6,991 07-20-2021, 03:14 PM
Last Post: zetabeta
  Hardwired software or functionality imposed by companies or authorities MirceaKitsune 16 27,227 06-13-2021, 05:18 AM
  Other Payment options? & I'll buy used PinePhone 3/32 any distro 503d 5 11,336 01-23-2021, 05:30 AM
Last Post: 503d
  Latest PinePhone CE Manjaro - Charging issues: hardware or software? kern707 5 9,449 11-20-2020, 12:09 AM
Last Post: bcnaz
  Software back to basics Zweitaktmotor 4 10,956 12-13-2019, 03:57 PM
Last Post: bcnaz
