Remix OS issues:
1: Plug a network cable into the network port and the system pretty much hangs and reboots. (resolved this by reloading the current beta while having the network cable plugged in)
2: Remix OS pretty much hangs on anything. (After reloading, this seems to happen very little).
3. Obviously some Google Play applications just won't be compatible with this device or version. (Not shocking).
4. Downloads while being hardlined to network, are painfully slow.
5. Screensaver does not work.
Will update list as I find things. Feel free to post your issues too. Maybe we can form a large list.
Anyone else seeing these? is there a fix?
(04-22-2016, 08:12 AM)shepscrook Wrote: 1: Plug a network cable into the network port and the system pretty much hangs and reboots.
This issue has been fixed, please use this version: http://wiki.pine64.org/index.php/Pine_A6...60415_Beta
I suppose I should have listed what version I used.
I used the Release 20160415 Beta found at:
files.pine64.org/os/remix0S2.0_pine64_B2016041501.zip
I'm going to re-download and try it again.
I have a similar issue using the same version, the only difference is I have the wifi/bluetooth module. Everything seems incredibly slow, which is a shame as I do like the UI. After everything is loaded I cannot get an internet connection even though it shows 4 bars of signal strength.
I have the same problem. It boots, then very slow and a "System process stopped" message, which when i hit "accept" makes the device reboot, I burned the image you talk about two or three times already and keep having these issues. I am using the 1GB board with wireless dongle. Any idea what might be?
Thanks!
I've been using RemixOS on my 1GB board, the internet was slow, until i took the wifi antenna and stuck it upright above the board. The Wifi connection improved greatly, i would try adjusting your antenna and see how that goes for you.
If I've helped you with something, please leave a rating for my responses.
I have my PineA64 hardwired and internet overall is slow. Downloading Apps from the play store is painful.
I found that if I had the network cable attached while doing the initial boot (setup). Everything worked fine. Network now works. I've been running Remix OS for a few days now and it's not bad. A little slow, but works.
i just tried it and it was slow and wired network didn't work on my 2gb model. i formatted the drive thinking it would just expect to make use of the 32gb but it actually wiped the disk. lol, saved me trouble for when i move back to arch.
  sourround sound - Remix MrSarkasmus 0 4,537 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 59,015 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,335 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 232,282 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 6,835 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 6,655 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 24,018 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 31,744 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 12,278 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 5,998 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
