Any Progress on the new update for Remix OS?
#71
(04-20-2016, 04:32 AM)tllim Wrote:
(04-20-2016, 03:55 AM)Luke Wrote:
(04-19-2016, 10:10 AM)tllim Wrote:
(04-19-2016, 10:06 AM)King Patte Wrote: Does the Ethernet functional in the new Version from Remix OS?
And will there be a new DD Image?
I don't know why, but just the DD Images works for me.
I have tested the Ethernet function on Pine A64+ 2GB board. We will release the DD image on this week. The DD image also "avoid" the initial first time boot up sluggishness.
Glad to hear that a DD img is coming, seeing as I cannot make the phoenix card to burn the img properly. I have tried 20-odd times and I am about to give up.
The DD img will be posted tomorrow.
Any ETA of the DD img ?
DD image:
for 64gb card:
https://drive.google.com/file/d/0B_6QLyX...sp=sharing
for 32gb card:
(04-21-2016, 09:39 AM)janjwerner Wrote: DD image:
for 64gb card:
for 32gb card:
excellent - will give this a spin *fingers crossed*
for 64gb card:
for 32gb card:
Do i need this size of Card for this? Or can i use a 16GB Card?
Pine 64 2GB Version
Pine64 Emulator Try
Android:
NES:
SNES: Super Retro 16| Controller works| Games 60FPS
GB/GBC:
GBA:
N64:
Anyone else got a problem with communicating with google servers? It suggests retrying it again... i did.
at least the ethernet bug is gone, but i can't do much on my 32gb pine 64 with 2gb ram and the new os version, when i can't log into my google account^^
i am on a 100mbit ethernet hub, the pine is a trusted device in my router (fritz.box) so there shouldn't be any issues anymore, except there is another problem now with (maybe) google certification?
(04-21-2016, 01:58 PM)Rhymoore Wrote: Anyone else got a problem with communicating with google servers? It suggests retrying it again... i did.
A wild maybe unhelpful stab in the dark, Is you Time and date and time zone set correctly? I've not had this issue so can't be sure  Huh
for 64gb card:
for 32gb card:
Yes you need that size card. But you can shrink the size of the Image using http://softwarebakery.com/shrinking-images-on-linux
 If you really want too.
for 64gb card:
for 32gb card:
I tried the DD image for 32gb card. And it does not boot at all. I think that there is a Error with the img File. Its just 881 MB. The others had a Size of 7GB.
Pine 64 2GB Version
Pine64 Emulator Try
Android:
NES:
GB/GBC:
GBA:
N64:
did you gunzip it first ?
(04-22-2016, 09:31 AM)janjwerner Wrote: did you gunzip it first ?
I unzip it and try again. I will tell you if its worked.
Edit: I can't use it, because the Programm says that i have 800MB too less.
Pine 64 2GB Version
Pine64 Emulator Try
Android:
NES:
GB/GBC:
GBA:
N64:
for 64gb card:
for 32gb card:
So I too had no luck with getting the img to work, but suspect the problem might be with my SD card (which reads 31GB). I have ordered a new one and will try tomorrow and report back Smile
  sourround sound - Remix MrSarkasmus 0 5,008 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 62,781 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,858 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 245,574 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,381 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,182 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,192 04-17-2017, 04:20 AM
Last Post: simplexdan
  Update Feature not working on 2.0 2016071801 Jaylc 0 4,496 02-28-2017, 06:50 PM
Last Post: Jaylc
  Stuck at Remix OS logo leongzhi 9 33,307 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,176 12-19-2016, 07:49 PM
Last Post: Toriless
