Testing GPS
Here are the steps to enable and help testing GPS on Ubuntu Touch.
I strongly suggest you open SSH first:
sudo mount -o rw,remount / sudo umount /etc/init/ssh.override sudo rm /etc/init/ssh.override sudo start ssh
Step 1)
You need to be using OTA version 27 (May 17th) or newer. You should be on devel channel.
Step 2)
Fetch uNav and Pure Maps from OpenStore
Step 3)
Mount the volume so its rewritable
Step 4)
Install gpsd
sudo ubports-qa install xenial_-_edge_-_gpsd
Step 5)
Start GPS + some magic
sudo gpsd start sudo restart ubuntu-location-service initctl unset-env --global UBUNTU_PLATFORM_API_BACKEND initctl set-env --global UBUNTU_PLATFORM_API_BACKEND=touch_mirclient
Step 6)
Open uNav and request it to fetch your location.
Report issues, fixes, ideas and everything else related to the topic of location services on Ubuntu Touch in this thread.
Unav works, but PureMaps is unable to detect my locatiion.
OTA 28 here (no update found today)
PureMaps and uNav crash immediately when requesting GPS position.
This means PureMaps is unusable now since it remembers the GPS position request state and crashes immediately after start.
Switching GPS off in the GUI does not solve the problem. PureMaps and uNav still crash.
Where can I find logs to give details ?
Thank You! That worked for me.
PureMaps needed some Token like from Mapbox.
But Yes. My PinePhone BH now supports GPs on UT.
Great.
GPS only works until the next reboot.
After the reboot I need to reset UBUNTU_PLATFORM_API_BACKEND, and restart GPS service.
I guess, this should be pretty easy to set to run at startup
(05-19-2020, 10:20 AM)Dedik Wrote: Thank You! That worked for me.
But Yes. Its the next functionality.
Great.
if you look at their app when you install it , expand the write up,and it will explain whats needed, just to help keep it free mainly
Great.
This all is testing.
You are shurely right to have a strange look at your apps.
Great.
Did it work multiple times in a row (without a reboot)?
(05-19-2020, 12:03 PM)afigegoznaet Wrote: GPS only works until the next reboot.
You are right after reboot, its gone.
The UBUNTU_PLATFORM_API_BACKEND can be edited in unity8 files in /usr/share/upstart/sessions; I edited both unity8.conf and unity8.override, but possibly just one would suffice.
The gps daemon still needs a restart
  Testing Crust Deep-sleep Luke 53 115,106 08-06-2020, 11:10 AM
Last Post: erikinkinen
  Testing and Donating jmasters 2 7,188 06-30-2020, 11:32 PM
Last Post: jmasters
