Any Progress on the new update for Remix OS?
#61
(04-19-2016, 04:23 PM)anthonypunt Wrote: Thank you! I set my switch port to 100mbps and every thing works now!
So Mine is running everything fine except it seems like everything i play has a static sound that comes and goes. I changed HDMI cords, tried different video sources... what else can i try?
It is very annoying when you are trying to get into a movie and all of a sudden you get a deep static noise in the background for about 5-30 sec then goes away for a 1 to 3 minutes. Any steps i can try that i can't think of?
(04-19-2016, 10:10 AM)tllim Wrote:
(04-19-2016, 10:06 AM)King Patte Wrote: Does the Ethernet functional in the new Version from Remix OS?
And will there be a new DD Image?
I don't know why, but just the DD Images works for me.
I have tested the Ethernet function on Pine A64+ 2GB board. We will release the DD image on this week. The DD image also "avoid" the initial first time boot up sluggishness.
Glad to hear that a DD img is coming, seeing as I cannot make the phoenix card to burn the img properly. I have tried 20-odd times and I am about to give up.
The DD img will be posted tomorrow.
And then the symptoms will change. Now people will fail burning the image with Phoenix Card stuck at '[boot]Burn success' followed by 'Error'. With dd they will succeed burning the image but then fail booting.
What about recommending Rufus instead? Rufus at least allows to verify whether the image has been burnt correctly.
Phoenix card dose not work with my built in SD reader for some reason. But works with an old usb adapter, attached to a OTG cable, Lol!
(04-20-2016, 05:48 AM)marshmel Wrote: Phoenix card dose not work with my built in SD reader for some reason. But works with an old usb adapter, attached to a OTG cable, Lol!
And guess what? The answer is super simple: reason N° 2, 2nd sentence: http://forum.pine64.org/showthread.php?tid=514 (you experienced 'data corruption on the fly' that Phoenix Card was able to detect but is not responsible for. With the old USB adapter it took longer and no data corruption occured so Phoenix Card's checksum verify succeeded and it doesn't stop with "Error" in between but burned all partitions on the card).
Now with 'DD images' in a similar situation you burn the image without any indication of an error and the board doesn't boot up or crashes later (since it's still data corruption -- this time undetected. And that makes me LOL! Since all my recommendations to get past this point are happily ignored by both Pine64 folks and users. It's too funny that this is still an issue the forums are full of  Big Grin  )
LoL Thanks for clearing that up  Cool
I have installed it and it works fine apart from my ethernet connection. I get activity lights but no IP address. The cable works OK as I use this on another machine. Also, can you use a wifi dongle with Remix OS?
When are we getting the DD image for latest build?
So just to add something.. I have put a 100MB switch between my Pine and my gigabit switch and this fixed my issue. May help someone else!
  sourround sound - Remix MrSarkasmus 0 4,619 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 60,096 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,474 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 236,098 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 6,966 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 6,791 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 24,352 04-17-2017, 04:20 AM
Last Post: simplexdan
  Update Feature not working on 2.0 2016071801 Jaylc 0 4,220 02-28-2017, 06:50 PM
Last Post: Jaylc
  Stuck at Remix OS logo leongzhi 9 32,186 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 12,550 12-19-2016, 07:49 PM
Last Post: Toriless
