replacement batterie doesn't fit
Because the batterie auf my PP was 'grown' after one week using I have contacted the support. After a long conversion / discussion I have bought a new one from Amazon as the support ream has told me:
----------------------However, you may purchase the replacement battery from any online market(Amazon) which is same model with Samsung J7(2015).
But the J7 batterie is more than 1mm bigger as the original one. Now I'm still can't use my PinePhone.
What a bad support !!!!!!!!!!!!!!!!!!!!! Never again !!!!!!!!!!!!!!!!!!!!!!
My original Samsung battery is 0.8mm bigger, but still fits easily into the phone.
You should of course cut off the two tabs in the lower corners.
  Screen Replacement Instructions erikkugel 5 12,441 02-24-2025, 06:55 AM
Last Post: anonymous
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,905 10-12-2023, 01:03 PM
Last Post: robthebold
  Microphone replacement SocialNetworkingWasAMistake 1 4,085 08-05-2022, 03:16 PM
Last Post: calinb
  Wifi doesn't respond jmlich 6 10,366 02-04-2022, 06:50 PM
Last Post: bcnaz
  Screen replacement Csanderson0313 4 7,542 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 30,467 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 4,801 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 12,792 08-29-2021, 07:03 AM
Last Post: bcnaz
  inner earpiece speaker replacement dcinoz 4 9,193 07-24-2021, 04:37 AM
Last Post: dcinoz
  computer doesn't recognize pinephone for OS flashing Xzska-collab 3 7,639 06-29-2021, 09:37 AM
Last Post: Xzska-collab
