Trouble Installing PHP5
I'm trying to install PHP5 so that I can run a Dokuwiki server, but I get this error message:
ubuntu@Pine64:~$ sudo apt-get install php5-fpm php5-gd                                   Reading package lists... Done Building dependency tree Reading state information... Done Package php5-fpm is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package php5-gd is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'php5-fpm' has no installation candidate E: Package 'php5-gd' has no installation candidate
I've added additional repositories and then run apt-get update, but no luck.
sudo add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) main universe restricted multiverse"
Any suggestions on how to get PHP5 installed?
Thanks.
(04-19-2016, 08:59 AM)JCMPine64 Wrote: I'm trying to install PHP5 so that I can run a Dokuwiki server, but I get this error message:
Thanks.
In my sources there only is php7.0 available.….
Maybe you give this a try?
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
PHP7 installs just fine on Ubuntu
root@pine64-2gb:~# apt-get install -s php7.0-fpm Reading package lists... Done Building dependency tree       Reading state information... Done The following packages were automatically installed and are no longer required:  libnih1 libnl-route-3-200 seccomp ubuntu-core-security-apparmor  ubuntu-core-security-seccomp ubuntu-core-security-utils ubuntu-snappy-cli Use 'apt autoremove' to remove them. The following additional packages will be installed:  php-common php7.0-cli php7.0-common php7.0-json php7.0-opcache  php7.0-readline Suggested packages:  php-pear The following NEW packages will be installed:  php-common php7.0-cli php7.0-common php7.0-fpm php7.0-json php7.0-opcache  php7.0-readline 0 upgraded, 7 newly installed, 0 to remove and 60 not upgraded. Inst php-common (1:35ubuntu6 Ubuntu:16.04/xenial [all]) Inst php7.0-common (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Inst php7.0-json (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Inst php7.0-opcache (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Inst php7.0-readline (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Inst php7.0-cli (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Inst php7.0-fpm (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php-common (1:35ubuntu6 Ubuntu:16.04/xenial [all]) Conf php7.0-common (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php7.0-json (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php7.0-opcache (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php7.0-readline (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php7.0-cli (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64]) Conf php7.0-fpm (7.0.4-7ubuntu2 Ubuntu:16.04/xenial [arm64])
There is no PHP5 in Xenial as it is outdated and slow.
(04-19-2016, 11:52 AM)longsleep Wrote: PHP7 installs just fine on Ubuntu
Yes, PHP7 installs just fine, but when I follow the instructions for installing DokuWiki it fails at
sudo nginx -t
Not sure if I screwed something up, if the instructions being for a VPS mean that it can't work, or if Pine64 can't do it.
  Networking trouble s21 22 43,784 04-05-2016, 06:06 PM
Last Post: rpfand
