OMV + VPN server + Pi Hole?
So, I have a RockPro64 running OMV that I purchased last year some time.  It's in the NAS case with 2 4TB HDDs, running as separate drives.  It's been working great, with Emby plug in.  I had an issue where I lost power (hadn't bought a UPS yet), and the main media drive crapped out.  That's all solved.  Now, however, I'm looking at using a SBC to run a VPN server, and pi hole to remove ads from my network.  I was looking at an Odroid N2 to run this.  However, after some research, I'm thinking maybe I can run all 3 services on the RP64...  It seems to be powerful enough for it.  Is it wise to do an all in one, or should I keep them separated?
(03-16-2020, 08:36 AM)odhinnhrafn Wrote: So, I have a RockPro64 running OMV that I purchased last year some time.  It's in the NAS case with 2 4TB HDDs, running as separate drives.  It's been working great, with Emby plug in.  I had an issue where I lost power (hadn't bought a UPS yet), and the main media drive crapped out.  That's all solved.  Now, however, I'm looking at using a SBC to run a VPN server, and pi hole to remove ads from my network.  I was looking at an Odroid N2 to run this.  However, after some research, I'm thinking maybe I can run all 3 services on the RP64...  It seems to be powerful enough for it.  Is it wise to do an all in one, or should I keep them separated?
That should be fine. I'm running e.g. nextcloud/openVPN/tvheadend/syncthing/nginx/mariadb (several)/nfs/samba/aria2... and more mainly in docker containers.
One java application I had to move to my spare rockpro64, since it is a bit sensible when it comes to memory or timing issues..
I guess you are talking about a Home/small office server!
M
M
I'm not even using it as heavily as you.  I have OMV with Emby, but I think I'll be moving over to Plex.  It's just a NAS, right now.  I have an Intel NUC running as my HTPC (wife doesn't want to adapt to Linux), so the load on the RP64 is pretty light.
Seeing your list, I can definitely add OpenVPN and Pi Hole to it, with no issues to performance.  I feel better about adding more uses to this board.  I'll definitely enjoy putting my whole network on a VPN instead of just a device here and there when I'm downloading.
How easy was it to get Docker working on your OMV?  Thank you much for your response!
M
I'm not using OMV. I was using that before. But now I have a plain debian installation with a self compiled kernel.
So docker install was like you will find tutorials and explainations in the Net.
Currently I run several contains via docker-compose, but docker-compose you need to install/cross-compile yourself for arm. I think I followed this one https://github.com/ubiquiti/docker-compose-aarch64
M
  Home Server with RAID 1 SATA M2 SSDs runyor 8 24,112 01-22-2025, 04:40 AM
Last Post: Davidmenk3
  Smart TV & server storz 1 5,093 01-19-2024, 01:59 PM
Last Post: dairymilkbatman
  Umbrel Server Shaeroden 0 4,427 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 27,109 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 8,984 01-17-2021, 11:33 AM
  [WIP] backup server (4 sata HDDs + ZFS) rolando 8 19,874 06-30-2020, 10:58 AM
Last Post: dml-pc
Video ARMBand an easily configured Home Media Server gabrielsr 2 10,896 07-22-2019, 04:56 AM
Last Post: stuartiannaylor
