cache/apt/archives FULL
Hi all,
I've running UT on my (BH) PinePhone (off the SD card) for a week or so.
I run apt update && apt upgrade every few days, but when I ran it today I got an error message after I ran apt upgrade: E: You don't have enough free space in /var/cache/apt/archives/
I installed the image using "Rufus" on a clean/new SD card.  Haven't had any issues running Update/upgrade until now.
Any ideas for a fix other than wiping the SD card and starting over???
Thanks.
(02-19-2020, 07:23 AM)canadien666 Wrote: Hi all,
Thanks.
  FYI, apt clean and apt autoclean did not rectify the problem...
I think you forgot to resize the sd card partition. In linux you can do that like this:
sudo parted /dev/mmcblk2p1 resizepart 1 100%
sudo resize2fs /dev/mmcblk2p1
Replace the device name (/dev/mmcblk2p1) with your device.
Thanks, that makes perfect sense... I knew i forgot something!
  n00b questions - can I add additional repos? how is UT different from a "full" ubuntu arturo2bodegas 6 14,407 07-11-2020, 04:25 PM
Last Post: dawg161
