pmbootstrap - choose different ui after first run
After you've run pmbootstrap once and chosen a ui, it seems to cache that first choice somewhere so that subsequent installs don't offer you a choice of ui. I'd like to try out some other ui's as the plasma-mobile ui isn't quite what I'm looking for. I did run pmbootstrap zap but that didn't affect this issue. How can I run subsequent pmbootstrap install and be prompted again to choose my ui?
I'll make another post with the problems I've run into with the plasma-mobile ui and I'll try to help with that as much as I'm able, however since it isn't the ui I'm looking for, I'll also be trying out other os's and ui's and likely dedicating more time to them.
did you run pmbootstrap shutdown?
(02-13-2020, 04:09 PM)ankylo Wrote: did you run pmbootstrap shutdown?
I didn't. I'll try that now. Somehow I haven't seen anything about shutdown yet but I'll give that a try (and go through the doc's more thoroughly). Will report back.
Edit: that fixed it for me. Thanks ankylo
Edt2: trying to give you rep but the rate button shows "javascript:void(0)". I'll see if there's a meta section where I can raise the question why.
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 10,802 05-28-2023, 10:54 PM
Last Post: Avisando
  pmbootstrap error lat 2 8,173 12-22-2020, 06:32 PM
Last Post: lat
  pmbootstrap issues IVp 3 10,589 09-24-2020, 02:24 AM
Last Post: Pinethom
  pmbootstrap build large keyboard not usable u20200719 5 12,287 07-25-2020, 02:31 PM
Last Post: u20200719
  pmbootstrap to sdcard Jeb5Blovrueb 34 79,816 07-07-2020, 04:17 AM
Last Post: fernando_c_m
  Is it possible to pre-configure wifi and ssh with pmbootstrap? kelbot 2 9,098 07-06-2020, 01:55 AM
Last Post: ChriChri
  Dumb question: do I have to use pmbootstrap? quixote 5 11,691 06-11-2020, 09:23 AM
Last Post: plainenough
  pmbootstrap on Mac OSX srfne 2 11,397 02-29-2020, 04:15 PM
Last Post: srfne
  Does pmbootstrap install the latest image? mypine 4 12,029 02-20-2020, 01:02 PM
Last Post: mypine
  pmbootstrap to sdcard on debian 10 ctsm63 2 7,565 01-29-2020, 03:53 PM
Last Post: ctsm63
