Screen brightness and PWM
Any hardware devs able to answer this?
Basically, does the display on the PinePhone use PWM to control brightness?
I hope not! But if so, what's the duty cycle?
Looking at the DTS, it seems it uses Linux kernel's PWM driver(?) to adjust brightness, does that imply PMW at the hardware level or not neccessarly?
Thanks.
PS: Whilst at it, how about the PineTab?
(02-06-2020, 06:35 AM)hex Wrote: I hope not! But if so, what's the duty cycle?
I think you would like to ask about it's frequency rather than duty cycle.
Correct, can't edit it tho Big Grin
Not necessarily - see the schematic. I've not found an english datasheet for the AP3127B025 listed, but you can buy them on alibaba for 3 cents.
Okay, I looked at the schematics it didn't help, its beyond me!
The good news is phone is arriving Thurs, and I have a slow mo digi cam, I'll test it and report back.
Thanks.
I've found the datasheet if anyone is interested: http://files.remont-aud.net/baza/dc_dc/data/AP3127B.pd
Thanks for the datasheet. The chip isn't being used quite as the datasheet suggests, but the end result should be similar - the pwm signal is low pass filtered and used to control the current in a switch mode current source that's switching at ~1MHz. I don't know the pwm frequency and haven't done the calcs for the filter, but brightness ought to vary a lot less than if it were straight PWM of LEDs.
Okay, I can confirm.
Using a 1000FPS capable camera, I can confirm there is no blacklight flicker whatsoever, so it's good news, I hope the tablet will be equally so.
  Screen dying already? marcih 156 292,854 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 11,317 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 1,927 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,360 10-12-2023, 01:03 PM
Last Post: robthebold
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,251 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,454 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 8,770 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 49,705 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 5,007 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 7,006 01-10-2022, 09:26 PM
Last Post: Csanderson0313
