Cannot detect keyboard
I have tried to build the pine64 image by using the steps given in https://github.com/longsleep/build-pine64-image with kernel 3.10 from BSP not the mainline kernel. I can reach the login page but cant use the keyboard.
I have compare the syslog generated from the downloaded image and my image, found the differences as follows:
Log generated from downloaded image:
[Image: iSvREoXl.png]
Log from my image:
[Image: hr3LZDYl.png]
Any ideas on this? Huh
(04-12-2016, 08:31 PM)dragoon Wrote: I have tried to build the pine64 image by using the steps given in https://github.com/longsleep/build-pine64-image with kernel 3.10 from BSP not the mainline kernel. I can reach the login page but cant use the keyboard. Any ideas on this?  [Image: huh.png]
I tried to move your thread to the Linux General section so that it might get noticed quicker and since it applies specifically to Linux, but see you have re-posted it here, which is totally up to you. Hope someone can provide you with an answer soon Smile
I thought i posted in wrong category...   Big Grin
Hehe, nope. Do you want me to move it to Linux General, or are you happy here?
Ok.. appreciate that! Thanks..
I tried to move your thread to the Linux General section so that it might get noticed quicker and since it applies specifically to Linux, but see you have re-posted it here (General Discussion) which is totally up to you. Hope someone can provide you with an answer soon Smile
Ok, moved. Hope you get help with your issue soon Smile
By the way, have you tried several different keyboards, or just one? Also, how does the keyboard connect to the Pine? (USB, Bluetooth, etc)
(04-12-2016, 08:34 PM)SkairkrohBule Wrote: I tried to move your thread to the Linux General section so that it might get noticed quicker and since it applies specifically to Linux, but see you have re-posted it here (General Discussion) which is totally up to you. Hope someone can provide you with an answer soon Smile
I just tried one keyboard cause it can be detected by using the downloaded xenial image. Forgot to mention that it is USB keyboard.
What is the brand and model of the keyboard? Does it work in other Linux computer without issues?
I know the longsleep kernel do not have all the usb drivers compiled in, this includes few missing keyboard drivers. But generic usb keyboards should work. I had no problem with mine.
(04-28-2016, 04:27 PM)baryluk Wrote: What is the brand and model of the keyboard? Does it work in other Linux computer without issues?
I try several USB keyboards and works.
  Pre-Configure Wifi on Pine64 without Keyboard/mouse bortek 4 10,767 01-23-2017, 02:04 PM
Last Post: bortek
Users browsing this thread:
