Remedial Docker lessons
I thought I understood Docker, but maybe not. I'm running ayufan's Ubuntu on my ROCK64; uname identifies it as aarch64. When I run Docker (via Kubernetes) and ask for a multi-architecture image, I get this error:
    no matching manifest for linux/arm/v8 in the manifest list entries
But Docker Hub lists the image (rook/ceph:v1.1.2) as built for both amd64 and arm64 architectures. I thought aarch64 and arm64 meant the same thing, with userland calling the architecture aarch64 and kernel calling it arm64. Is that not true? How are these names related to linux/arm/v8?
If this machine pulled an arm64 image, would it be able to run it? Maybe my Docker is just misconfigured so it doesn't recognize what it can run.
Did you ever find a solution to this issue? I'm running into the same item, and so far have turned up nothing.
(12-11-2019, 10:47 PM)lordbowlich Wrote: Did you ever find a solution to this issue? I'm running into the same item, and so far have turned up nothing.
I once saw someone mention how people just default to assuming Intel/x64 for their manifests. Perhaps this link helps:
https://thedoh.dev/docker/multi-arch.html
I'm starting on my own road down Pine64 and k8s, so I can't say things for sure.
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 7,633 09-19-2019, 07:00 AM
Last Post: Malmgren
  help building a docker image jata 6 13,560 07-12-2019, 08:47 PM
Last Post: hmuller
  Docker Mssql Riverman 5 11,552 07-09-2018, 11:26 PM
Last Post: pfeerick
  docker contaainer error on "docker login" edwinbmiller 0 2,843 06-18-2018, 10:08 AM
Last Post: edwinbmiller
  Kodi + Docker - what are the image options for Rock64 to support this? zarusz 0 4,126 05-20-2018, 01:41 AM
Last Post: zarusz
  Has someone managed to get Docker running yet? Sven 17 30,092 12-24-2017, 06:52 PM
Last Post: xnathanh
