Remix OS Running on Pine A64
#41
(04-05-2016, 10:32 AM)pine771 Wrote:
(04-04-2016, 08:33 PM)yella-pine64 Wrote:
(04-04-2016, 07:05 PM)yella-pine64 Wrote: I'm going to try using the Remix OS with an off brand USB to 10/100 lan adapter Ive got laying around.  I've verified it functions in every version of Linux, windows and OSX ive tried.
on the 2GB pine the remix ethernet worked fine with a 10/100 usb 2.0 adapter from microcenter.
 You mean the 2gb RAM.model works with and USB lan adapater with remix os?
Like this?
https://www.google.es/search?q=usb+lan+a...dLbaZGM%3A
Yeah Remix OS worked fine when I used the Inland brand USB 2.0 10/100 ethernet adapter.  DHCP was not working but assigning a static IP got me on the internet with it. 2GB RAM pine
Do we have an ETA on the new release that will solve the Ethernet problem ?
(04-07-2016, 07:31 PM)Luke Wrote: Do we have an ETA on the new release that will solve the Ethernet problem ?
I am wondering the same thing. I would love to get mine up and running. I had it running without the ethernet but I need the internet on it and I did not get the wifi/bluetooth as I will always have it in reach of ethernet. Any update on when this will be resolved would be appreciated.
Next few days. The issue has been identified and will confirmed the fix work properly on Monday.
(04-04-2016, 10:41 AM)pine.tree Wrote: As they are both with the 2gb board, and both have the same symptoms, i would assume they are related to each other. Hopefully RemixOS devs can fix the issue.
From what i understand, developers were only given 1GB boards, (like me and my team), so the 2gb board was never tested with either images. The problem was only recently discovered with backers getting their 2gb boards and having issues.
oh thats bad Undecided
I figured once you unplug the ethernet cable it all works and runs fine, you can even go into settings disable the ethernet and then plug the ethernet cable back in and it still works, just dont activate ethernet again xD
(2gb kickstarter board)
  sourround sound - Remix MrSarkasmus 0 5,008 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 62,726 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,853 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 245,501 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,381 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,181 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,191 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,303 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,172 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,484 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
