LSI SAS3801E
Did not boot.  Might have to flash to IT mode if possible.  Will try later.  Serial output:
DDR Version 1.20 20190314 In channel 0 CS = 0 MR0=0xB8 MR4=0x1 MR5=0xFF MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0xB8 MR4=0x1 MR5=0xFF MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 400MHz 0,1 channel 0 CS = 0 MR0=0xB8 MR4=0x1 MR5=0xFF MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0xB8 MR4=0x1 MR5=0xFF MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 Channel 0: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 248 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15262MB FwPartOffset=2000 , 0 StorageInit ok = 44206 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xd35dc RunBL31 0x10000 NOTICE:  BL31: v1.3(debug):370ab80 NOTICE:  BL31: Built : 09:23:41, Mar  4 2019 NOTICE:  BL31: Rockchip release version: v1.1 INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    plat_rockchip_pmu_init(1181): pd status 3e INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:   Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400) Model: Rockchip RK3399 Evaluation Board PreSerial: 2 DRAM:  3.9 GiB Sysmem: init Relocation Offset is: f5bfa000 I2c speed: 400000Hz PMIC:  RK808 vdd_center 900000 uV vdd_log init 900000 uV rk_board_init PWM2 pinctrl init fail! vdd_center 900000 uV                DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled                DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling                 LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling              SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled                   dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)                  vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)               vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)        vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling           vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)         vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, disabled | suspend     -61uV, enabling               vcc5v0-sys@     vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)    vcc12v-pcie-regulator@    vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38) vdd_log init 900000 uV                  vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV              vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38) MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1 Invalid bus 0 (err=-19) *** Warning - spi_flash_probe_bus_cs() failed, using default environment In:    serial Out:   serial Err:   serial Model: Rockchip RK3399 Evaluation Board RKPARM: Invalid parameter part table switch to partitions #0, OK mmc1 is current device do_rkimg_test found IDB in SDcard Bootdev(atags): mmc 1 PartType: DOS get part misc fail -1 boot mode: None CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)  aplll 816000 KHz  apllb 24000 KHz  dpll 800000 KHz  cpll 24000 KHz  gpll 800000 KHz  npll 600000 KHz  vpll 24000 KHz  aclk_perihp 133333 KHz  hclk_perihp 66666 KHz  pclk_perihp 33333 KHz  aclk_perilp0 266666 KHz  hclk_perilp0 88888 KHz  pclk_perilp0 44444 KHz  hclk_perilp1 100000 KHz  pclk_perilp1 50000 KHz Net:   eth0: ethernet@fe300000 Hit key to stop autoboot('CTRL+C'):  0 Could not find misc partition ANDROID: reboot reason: "(none)" load_android_image: Can't find part: boot Android boot failed, error -1. =Booting Rockchip format image= boot_rockchip_image kernel or boot part info error RKPARM: Invalid parameter part table switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 404 bytes read in 3 ms (130.9 KiB/s) 1: ROCKPRO Retrieving file: /Image reading /Image 25612296 bytes read in 2715 ms (9 MiB/s) append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current Retrieving file: /rk3399-rockpro64.dtb reading /rk3399-rockpro64.dtb 96363 bytes read in 14 ms (6.6 MiB/s) ## Flattened Device Tree blob at 08300000   Booting using the fdt blob at 0x8300000   Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000) Total: 3854.12 ms Starting kernel ... [UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported. [  OK  ] Started Forward Password Requests to Wall Directory Watch. [  OK  ] Reached target Paths. [  OK  ] Reached target Encrypted Volumes. [  OK  ] Reached target Swap.         Starting Restore / save the current clock...         Starting Journal Service... [  OK  ] Listening on /dev/initctl Compatibility Named Pipe. [  OK  ] Reached target Slices. [  OK  ] Mounted Debug File System. [  OK  ] Mounted POSIX Message Queue File System. [  OK  ] Started Create list of required sta…vice nodes for the current kernel. [  OK  ] Started Remount Root and Kernel File Systems. [  OK  ] Started Load Kernel Modules.         Mounting FUSE Control File System...         Mounting Configuration File System...         Starting Apply Kernel Variables...         Starting Load/Save Random Seed...         Starting udev Coldplug all Devices...         Starting Create Static Device Nodes in /dev... [  OK  ] Mounted Configuration File System. [  OK  ] Mounted FUSE Control File System. [  OK  ] Started Restore / save the current clock. [  OK  ] Started Apply Kernel Variables. [  OK  ] Started Load/Save Random Seed. [  OK  ] Started Create Static Device Nodes in /dev. [  OK  ] Reached target Local File Systems (Pre). [  OK  ] Reached target Local File Systems.         Starting Raise network interfaces...         Starting udev Kernel Device Manager... [  OK  ] Started udev Kernel Device Manager. [  OK  ] Started Journal Service.         Starting Flush Journal to Persistent Storage... [  OK  ] Started Flush Journal to Persistent Storage.         Starting Create Volatile Files and Directories... [  OK  ] Started Create Volatile Files and Directories.         Starting Update UTMP about System Boot/Shutdown... [  OK  ] Reached target System Time Synchronized. [  OK  ] Started Update UTMP about System Boot/Shutdown. [  OK  ] Started udev Coldplug all Devices. [  OK  ] Reached target System Initialization. [  OK  ] Started Daily Cleanup of Temporary Directories. [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [  OK  ] Listening on D-Bus System Message Bus Socket. [  OK  ] Reached target Sockets. [  OK  ] Reached target Basic System. [  OK  ] Started Boot and Home Patition Mount Service.         Starting System Logging Service... [  OK  ] Started D-Bus System Message Bus.         Starting LSB: Starts and stops Wicd...         Starting Avahi mDNS/DNS-SD Stack... [  OK  ] Started Regular background program processing daemon.         Starting Save/Restore Sound Card State...         Starting LSB: IPv4 DHCP client with IPv4LL support...         Starting Login Service... [  OK  ] Started Daily apt download activities. [  OK  ] Started Daily apt upgrade and clean activities. [  OK  ] Reached target Timers. [  OK  ] Started System Logging Service. [  OK  ] Started Save/Restore Sound Card State. [  OK  ] Found device /dev/ttyS2. [  OK  ] Started Avahi mDNS/DNS-SD Stack. [  OK  ] Started Login Service. [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [  OK  ] Reached target Sound Card.         Starting Load/Save RF Kill Switch Status... [  OK  ] Started Raise network interfaces. [  OK  ] Reached target Network.         Starting OpenBSD Secure Shell server... [  OK  ] Reached target Network is Online.         Starting LSB: Start NTP daemon...         Starting Permit User Sessions... [  OK  ] Started Load/Save RF Kill Switch Status. [  OK  ] Started Permit User Sessions. [  OK  ] Started Serial Getty on ttyS2. [  OK  ] Started Getty on tty1. [  OK  ] Reached target Login Prompts. [  OK  ] Started LSB: IPv4 DHCP client with IPv4LL support. [  OK  ] Started LSB: Start NTP daemon. [  OK  ] Started OpenBSD Secure Shell server. [    2.894903] Internal error: : 96000210 [#1] SMP [    2.895308] Modules linked in: phy_rockchip_pcie midgard_kbase dw_hdmi_i2s_audio rockchip_saradc [    2.896109] CPU: 1 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1 [    2.896682] Hardware name: Pine64 RockPro64 (DT) [    2.897103] Workqueue: deferwq deferred_probe_work_func [    2.897568] task: ffffffc0f1484380 task.stack: ffffffc0f1550000 [    2.898093] PC is at rockchip_pcie_rd_conf+0x164/0x1b4 [    2.898545] LR is at rockchip_pcie_rd_conf+0x154/0x1b4 [    2.898995] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5 [    2.899639] sp : ffffffc0f15537e0 [    2.899932] x29: ffffffc0f15537e0 x28: 0000000000000000 [    2.900407] x27: 0000000000000001 x26: 0000000000000000 [    2.900880] x25: 0000000000000000 x24: ffffffc0eed85000 [    2.901355] x23: 0000000000000000 x22: 0000000000000004 [    2.901829] x21: ffffffc0f0b2f028 x20: ffffffc0f155386c [    2.902302] x19: ffffff8014100000 x18: 0000000000000005 [    2.902775] x17: 0000000000000000 x16: ffffff800811518c [    2.903248] x15: 0000000000000000 x14: 000000000000000a [    2.903724] x13: ffffff80898f48e7 x12: 0000000000000030 [    2.904197] x11: 0000000000000006 x10: ffffff80098f48ef [    2.904669] x9 : 0000000005f5e0ff x8 : 616373203a31303a [    2.905141] x7 : 3030303020737562 x6 : ffffff80098f4914 [    2.905614] x5 : ffffff80084a10bc x4 : 0000000000000000 [    2.906086] x3 : 000000000000000b x2 : 0000000000000800 [    2.906559] x1 : ffffff8012c00008 x0 : ffffff8014000000 [    2.907032] [    2.907032] PC: 0xffffff80084a11a0: [    2.907468] 11a0  54fffd01 39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273 [    2.908222] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1 [    2.908991] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f [    2.909748] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013 [    2.910500] 1220  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1 [    2.911250] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0 [    2.912012] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4 [    2.912764] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f [    2.913517] [    2.913517] LR: 0xffffff80084a1190: [    2.913955] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3 [    2.914709] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9 [    2.915461] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f [    2.916214] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39 [    2.916966] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5 [    2.917717] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73 [    2.918466] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee [    2.919218] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002 [    2.919970] [    2.919970] SP: 0xffffffc0f1553760: [    2.920405] 3760  00000004 00000000 00000000 00000000 eed85000 ffffffc0 00000000 00000000 [    2.921157] 3780  00000000 00000000 00000001 00000000 00000000 00000000 f15537e0 ffffffc0 [    2.921906] 37a0  084a1210 ffffff80 f15537e0 ffffffc0 084a1220 ffffff80 600001c5 00000000 [    2.922655] 37c0  00100000 00000000 f155386c ffffffc0 ffffffff ffffffff 08f91428 ffffff80 [    2.923407] 37e0  f1553820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 eed85000 ffffffc0 [    2.924158] 3800  00000000 00000000 00000140 00000000 f15538ec ffffffc0 00000000 00000000 [    2.924910] 3820  f1553870 ffffffc0 0848210c ffffff80 f15538ec ffffffc0 eed85000 ffffffc0 [    2.925660] 3840  eed85000 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000 [    2.926412] [    2.926412] X0: 0xffffff8013ffff80: [    2.926847] ff80  ******** ******** ******** ******** ******** ******** ******** ******** [    2.927603] ffa0  ******** ******** ******** ******** ******** ******** ******** ******** [    2.928356] ffc0  ******** ******** ******** ******** ******** ******** ******** ******** [    2.929108] ffe0  ******** ******** ******** ******** ******** ******** ******** ******** [    2.929860] 0000 [    2.930019] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000 [  OK  ] Started LSB: Starts and stops Wicd. [  OK  ] Reached target Multi-User System. [  OK  ] Reached target Graphical Interface.         Starting Update UTMP about System Runlevel Changes... [    3.500186] failed to power up DHD generic adapter, 1 retry left [    3.516145] wifi_platform_set_power = 0 [    3.516485] ======== PULL WL_REG_ON(-1) LOW! ======== [    3.516930] [WLAN_RFKILL]: rockchip_wifi_power: 0 [    3.517382] [WLAN_RFKILL]: wifi shut off power. [    3.517783] wifi_platform_bus_enumerate device present 0 [    3.518274] ======== Card detection to remove SDIO card! ======== [    3.518809] sdio: host isn't  initialization successfully. [    3.519388] wifi_platform_set_power = 1 [    3.519728] ======== PULL WL_REG_ON(-1) HIGH! ======== [    3.520204] [WLAN_RFKILL]: rockchip_wifi_power: 1 [    3.520619] [WLAN_RFKILL]: wifi turn on power. -1 [    3.821085] wifi_platform_bus_enumerate device present 1 [    3.821552] ======== Card detection to detect SDIO card! ======== [    3.822098] sdio: host isn't  initialization successfully. [    3.964178] vendor storage:20160801 ret = -1 [    5.822200] failed to power up DHD generic adapter, 0 retry left [    5.838919] wifi_platform_set_power = 0 [    5.839270] ======== PULL WL_REG_ON(-1) LOW! ======== [    5.839713] [WLAN_RFKILL]: rockchip_wifi_power: 0 [    5.840136] [WLAN_RFKILL]: wifi shut off power. [    5.840534] wifi_platform_bus_enumerate device present 0 [    5.840996] ======== Card detection to remove SDIO card! ======== [    5.841532] sdio: host isn't  initialization successfully. [    5.842011] failed to power up DHD generic adapter, max retry reached** [    5.843116] unregister wifi platform drivers [    5.843492] wifi_platform_bus_enumerate device present 0 [    5.843956] ======== Card detection to remove SDIO card! ======== [    5.844505] sdio: host isn't  initialization successfully. [    5.844983] ======== dhd_wlan_deinit_plat_data ======== [    5.845452] dhd_module_init: Failed to load the driver, try cnt 0 [    5.846005] dhd_module_init: Failed to load driver max retry reached** [    5.846584] dhd_module_init: Exit err=-19 Debian GNU/Linux 9 localhost ttyS2 localhost login: [    9.930845] BUG: spinlock lockup suspected on CPU#1, kworker/u12:3/159 [    9.931424]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:3/159, .owner_cpu: 1 [    9.932201] CPU: 1 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1 [    9.932771] Hardware name: Pine64 RockPro64 (DT) [    9.933183] Workqueue: deferwq deferred_probe_work_func [    9.933645] Call trace: [    9.933869] [<ffffff80080881a4>] dump_backtrace+0x0/0x220 [    9.934343] [<ffffff80080883e8>] show_stack+0x24/0x30 [    9.934790] [<ffffff80084245ec>] dump_stack+0x98/0xc0 [    9.935235] [<ffffff80080e6c24>] spin_dump+0x84/0xa4 [    9.935672] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164 [    9.936174] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38 [    9.936708] [<ffffff8008088428>] die+0x34/0x1b4 [    9.937107] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70 [    9.937597] [<ffffff8008093324>] do_sea+0x80/0x94 [    9.938012] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8 [    9.938470] Exception stack(0xffffffc0f1553240 to 0xffffffc0f1553370) [    9.939035] 3240: ffffffc0f1484380 0000008000000000 ffffffc0f1553410 ffffff8008422884 [    9.939720] 3260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000 [    9.940404] 3280: ffffff80098f5148 0000000000000000 ffffffc0f15532b0 ffffff80080eda14 [    9.941088] 32a0: 0000000000000005 0000000000000000 ffffffc0f1553350 ffffff80080edb74 [    9.941772] 32c0: ffffffc0f15533d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee [    9.942457] 32e0: ffffffc0f155349c ffffff8014000000 0000000000000004 00000040ee856000 [    9.943142] 3300: 0000000000000002 ffffffc0f15534a0 ffffffc0f155349c 00000000ffffffff [    9.943826] 3320: ffffff800991081f 0000000005f5e0ff ffffff80098f48ef 0000000000000006 [    9.944511] 3340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000 [    9.945195] 3360: ffffff800811518c 0000000000000000 [    9.945624] [<ffffff80080825cc>] el1_da+0x24/0x84 [    9.946039] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8 [    9.946566] [<ffffff8008084cac>] __show_regs+0x14c/0x198 [    9.947032] [<ffffff80080884ac>] die+0xb8/0x1b4 [    9.947431] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70 [    9.947920] [<ffffff8008093324>] do_sea+0x80/0x94 [    9.948334] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8 [    9.948791] Exception stack(0xffffffc0f1553610 to 0xffffffc0f1553740) [    9.949355] 3600:                                   ffffff8014100000 0000008000000000 [    9.950040] 3620: ffffffc0f15537e0 ffffff80084a1220 ffffffc0eed85120 000000000000006e [    9.950724] 3640: ffffffc0f15537f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86 [    9.951409] 3660: ffffffc0f1553752 0000000000000000 ffffffc0f1553680 ffffff8009692000 [    9.952093] 3680: 0000000000000140 00000000093c1b86 ffffffc0f1553860 ffffffc0f1553860 [    9.952778] 36a0: ffffffc0f1553830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008 [    9.953462] 36c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc [    9.954147] 36e0: ffffff80098f4914 3030303020737562 616373203a31303a 0000000005f5e0ff [    9.954832] 3700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7 [    9.955516] 3720: 000000000000000a 0000000000000000 ffffff800811518c 0000000000000000 [    9.956200] [<ffffff80080825cc>] el1_da+0x24/0x84 [    9.956616] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4 [    9.957174] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4 [    9.957739] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4 [    9.958274] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec [    9.958741] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164 [    9.959252] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc [    9.959748] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164 [    9.960268] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4 [    9.960794] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60 [    9.961292] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304 [    9.961870] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4 [    9.962399] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0 [    9.962904] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8 [    9.963431] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4 [    9.963966] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0 [    9.964456] [<ffffff80085c85f8>] __device_attach+0xac/0x128 [    9.964945] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30 [    9.965465] [<ffffff80085c794c>] bus_probe_device+0x38/0x98 [    9.965954] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8 [    9.966505] [<ffffff80080b2350>] process_one_work+0x224/0x368 [    9.967009] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c [    9.967492] [<ffffff80080b82ec>] kthread+0xe0/0xf0 [    9.967914] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20 [   24.154121] Watchdog detected hard LOCKUP on cpu 1 [   24.154535] ------------[ cut here ]------------ [   24.154958] WARNING: at kernel/watchdog.c:352 [   24.155340] Modules linked in: phy_rockchip_pcie midgard_kbase dw_hdmi_i2s_audio rockchip_saradc [   24.156128] [   24.156266] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.180 #1 [   24.156790] Hardware name: Pine64 RockPro64 (DT) [   24.157195] task: ffffff80096de2d0 task.stack: ffffff80096d0000 [   24.157717] PC is at watchdog_timer_fn+0x190/0x2e8 [   24.158139] LR is at watchdog_timer_fn+0x190/0x2e8 [   24.158560] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5 [   24.159204] sp : ffffffc0f7ed6d00 [   24.159496] x29: ffffffc0f7ed6d00 x28: 0000000000000001 [   24.159969] x27: ffffff80096d7720 x26: ffffff8009698260 [   24.160441] x25: ffffffc0f7ed9278 x24: ffffff80096d3d70 [   24.160913] x23: 0000000000000000 x22: 0000000000000012 [   24.161385] x21: ffffff80096d6000 x20: ffffff80096982d8 [   24.161858] x19: ffffff8009698000 x18: 0000000000000005 [   24.162329] x17: 0000000000000000 x16: 0000000000000000 [   24.162801] x15: 0000000000000000 x14: 000000000000000a [   24.163272] x13: ffffff80898f48e7 x12: 0000000000000030 [   24.163744] x11: 0000000000000006 x10: ffffff80098f48ef [   24.164215] x9 : 0000000005f5e0ff x8 : 4c20647261682064 [   24.164687] x7 : 6574636574656420 x6 : ffffff80098f491d [   24.165159] x5 : 00000000fffffffe x4 : 0000000000000002 [   24.165630] x3 : 00000040ee841000 x2 : 00000040ee841000 [   24.166102] x1 : 0000000000000000 x0 : 0000000000000026 [   24.166574] [   24.166574] PC: 0xffffff800812c6b8: [   24.167009] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020 [   24.167761] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860 [   24.168511] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260 [   24.169262] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a [   24.170012] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941 [   24.170764] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841 [   24.171515] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802 [   24.172266] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000 [   24.173019] [   24.173019] LR: 0xffffff800812c6b8: [   24.173454] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020 [   24.174206] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860 [   24.174958] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260 [   24.175709] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a [   24.176460] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941 [   24.177212] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841 [   24.177963] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802 [   24.178716] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000 [   24.179466] [   24.179466] SP: 0xffffffc0f7ed6c80: [   24.179901] 6c80  00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0 [   24.180651] 6ca0  09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6d00 ffffffc0 [   24.181402] 6cc0  0812c738 ffffff80 f7ed6d00 ffffffc0 0812c738 ffffff80 600001c5 00000000 [   24.182154] 6ce0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0 [   24.182902] 6d00  f7ed6d70 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0 [   24.183655] 6d20  9a174e5e 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000 [   24.184406] 6d40  098a07b8 ffffff80 9a174e5e 00000005 0812c5a8 ffffff80 9a1740b2 00000005 [   24.185156] 6d60  f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6de0 ffffffc0 081036e8 ffffff80 [   24.185910] [   24.185910] X6: 0xffffff80098f489d: [   24.186345] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.187097] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.187848] 48dc  00000000 00000001 00000000 30303020 32303330 34383730 34205d38 20636438 [   24.188600] 48fc  312e3432 31393538 58205d30 30203a36 66666678 38666666 38393030 39383466 [   24.189351] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331 [   24.190102] 493c  30303030 656e770a 70635f72 31203a75 3030300a 6c6c750a 625b2029 30207375 [   24.190854] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e [   24.191605] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20 [   24.192358] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942 [   24.193113] [   24.193113] X10: 0xffffff80098f486f: [   24.193554] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.194301] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.195051] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.195803] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020 [   24.196554] 48ec  312e3432 35353632 34205d34 20636538 312e3432 31313339 58205d33 203a3031 [   24.197305] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e [   24.198057] 492c  74617473 36203a65 30303030 0a356331 30303030 656e770a 70635f72 31203a75 [   24.198808] 494c  3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29 [   24.199559] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69 [   24.200312] [   24.200312] X13: 0xffffff80898f4867: [   24.200755] 4864  ******** ******** ******** ******** ******** ******** ******** ******** [   24.201509] 4884  ******** ******** ******** ******** ******** ******** ******** ******** [   24.202262] 48a4  ******** ******** ******** ******** ******** ******** ******** ******** [   24.203013] 48c4  ******** ******** ******** ******** ******** ******** ******** ******** [   24.203763] 48e4  ******** ******** ******** ******** ******** ******** ******** ******** [   24.204516] 4904  ******** ******** ******** ******** ******** ******** ******** ******** [   24.205270] 4924  ******** ******** ******** ******** ******** ******** ******** ******** [   24.206024] 4944  ******** ******** ******** ******** ******** ******** ******** ******** [   24.206775] 4964  ******** ******** ******** ******** ******** ******** ******** ******** [   24.207531] [   24.207531] X19: 0xffffff8009697f80: [   24.207973] 7f80  ******** ******** ******** ******** ******** ******** ******** ******** [   24.208725] 7fa0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.209477] 7fc0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.210229] 7fe0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.210982] 8000  ******** ******** ******** ******** ******** ******** ******** ******** [   24.211735] 8020  ******** ******** ******** ******** ******** ******** ******** ******** [   24.212488] 8040  ******** ******** ******** ******** ******** ******** ******** ******** [   24.213240] 8060  ******** ******** ******** ******** ******** ******** ******** ******** [   24.213994] [   24.213994] X20: 0xffffff8009698258: [   24.214437] 8258  ******** ******** ******** ******** ******** ******** ******** ******** [   24.215188] 8278  ******** ******** ******** ******** ******** ******** ******** ******** [   24.215939] 8298  ******** ******** ******** ******** ******** ******** ******** ******** [   24.216691] 82b8  ******** ******** ******** ******** ******** ******** ******** ******** [   24.217442] 82d8  ******** ******** ******** ******** ******** ******** ******** ******** [   24.218195] 82f8  ******** ******** ******** ******** ******** ******** ******** ******** [   24.218948] 8318  ******** ******** ******** ******** ******** ******** ******** ******** [   24.219704] 8338  ******** ******** ******** ******** ******** ******** ******** ******** [   24.220457] [   24.220457] X21: 0xffffff80096d5f80: [   24.220900] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.221650] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.222400] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.223152] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.223902] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.224653] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.225403] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.226155] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [   24.226907] [   24.226907] X24: 0xffffff80096d3cf0: [   24.227349] 3cf0  00000000 00000000 096de2d0 ffffff80 000000c0 00000000 08c6cdb0 ffffff80 [   24.228101] 3d10  00000001 00000000 080913c4 ffffff80 096d3d30 ffffff80 080914b8 ffffff80 [   24.228853] 3d30  096d3e40 ffffff80 08c6d42c ffffff80 096d3d80 ffffff80 08cee258 ffffff80 [   24.229606] 3d50  f252ea10 ffffffc0 f252e610 ffffffc0 f252e800 ffffffc0 00000002 00000000 [   24.230358] 3d70  00000000 00000000 00000000 00000000 ee841000 00000040 00000001 00000000 [   24.231107] 3d90  ffffffff 00ffffff 289e6297 00000000 0000b89c 00000000 00000000 00000000 [   24.231857] 3db0  b5593519 00000032 08081800 ffffff80 00001000 00000000 00000000 00000000 [   24.232609] 3dd0  34d5d91d 00000000 ee841000 00000040 096de2d0 ffffff80 00000000 00000000 [   24.233361] [   24.233361] X25: 0xffffffc0f7ed91f8: [   24.233804] 91f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7ed9210 ffffffc0 [   24.234557] 9218  f7ed9210 ffffffc0 f7ed9220 ffffffc0 f7ed9220 ffffffc0 0812b194 ffffff80 [   24.235308] 9238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000 [   24.236060] 9258  00000001 00000000 00000006 00000000 00000005 00000000 f3288000 ffffffc0 [   24.236811] 9278  f7ed9278 ffffffc0 00000000 00000000 00000000 00000000 9a167700 00000005 [   24.237562] 9298  9a167700 00000005 0812c5a8 ffffff80 f7ed8c80 ffffffc0 00000000 0000000a [   24.238314] 92b8  0812c57c ffffff80 63746177 676f6468 0000302f 00000000 00000000 00000000 [   24.239067] 92d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000 [   24.239819] [   24.239819] X26: 0xffffff80096981e0: [   24.240262] 81e0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.241015] 8200  ******** ******** ******** ******** ******** ******** ******** ******** [   24.241768] 8220  ******** ******** ******** ******** ******** ******** ******** ******** [   24.242521] 8240  ******** ******** ******** ******** ******** ******** ******** ******** [   24.243274] 8260  ******** ******** ******** ******** ******** ******** ******** ******** [   24.244029] 8280  ******** ******** ******** ******** ******** ******** ******** ******** [   24.244782] 82a0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.245535] 82c0  ******** ******** ******** ******** ******** ******** ******** ******** [   24.246288] [   24.246288] X27: 0xffffff80096d76a0: [   24.246731] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0 [   24.247482] 76c0  00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000 [   24.248235] 76e0  00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0 [   24.248985] 7700  00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0 [   24.249736] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040 [   24.250488] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000 [   24.251239] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000 [   24.251990] 7780  0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000 [   24.252743] [   24.252743] X29: 0xffffffc0f7ed6c80: [   24.253186] 6c80  00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0 [   24.253937] 6ca0  09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6d00 ffffffc0 [   24.254687] 6cc0  0812c738 ffffff80 f7ed6d00 ffffffc0 0812c738 ffffff80 600001c5 00000000 [   24.255439] 6ce0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0 [   24.256190] 6d00  f7ed6d70 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0 [   24.256941] 6d20  9a174e5e 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000 [   24.257693] 6d40  098a07b8 ffffff80 9a174e5e 00000005 0812c5a8 ffffff80 9a1740b2 00000005 [   24.258445] 6d60  f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6de0 ffffffc0 081036e8 ffffff80 [   24.259195] [   24.259330] ---[ end trace 5f0a747bb1eb9978 ]--- [   24.259734] Call trace: [   24.259952] Exception stack(0xffffffc0f7ed6b20 to 0xffffffc0f7ed6c50) [   24.260517] 6b20: ffffff8009698000 0000008000000000 ffffffc0f7ed6d00 ffffff800812c738 [   24.261202] 6b40: 00000000600001c5 ffffff80080eda14 0000000000000026 0000000000000000 [   24.261887] 6b60: ffffffc0f7ed6c00 ffffff80080edb74 ffffffc0f7ed6c80 ffffff800937898b [   24.262571] 6b80: ffffff80096d6000 0000000000000012 0000000000000000 ffffff80096d3d70 [   24.263256] 6ba0: ffffffc0f7ed9278 ffffff8009698260 ffffff80096d7720 0000000000000001 [   24.263940] 6bc0: 0000000000000000 ffffff8009692000 0000000000000026 0000000000000000 [   24.264625] 6be0: 00000040ee841000 00000040ee841000 0000000000000002 00000000fffffffe [   24.265310] 6c00: ffffff80098f491d 6574636574656420 4c20647261682064 0000000005f5e0ff [   24.265994] 6c20: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7 [   24.266678] 6c40: 000000000000000a 0000000000000000 [   24.267109] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8 [   24.267623] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284 [   24.268156] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc [   24.268662] [<ffffff800810f1c0>] tick_handle_oneshot_broadcast+0x144/0x1c0 [   24.269268] [<ffffff8008c6de54>] rk_timer_interrupt+0x4c/0x5c [   24.269774] [<ffffff80080ef2fc>] handle_irq_event_percpu+0xf4/0x1f0 [   24.270323] [<ffffff80080ef448>] handle_irq_event+0x50/0x80 [   24.270814] [<ffffff80080f2d7c>] handle_fasteoi_irq+0xcc/0x134 [   24.271325] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44 [   24.271830] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8 [   24.272340] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c [   24.272821] Exception stack(0xffffff80096d3d70 to 0xffffff80096d3ea0) [   24.273385] 3d60:                                   0000000000000000 0000000000000000 [   24.274069] 3d80: 00000040ee841000 0000000000000001 00ffffffffffffff 00000000289e6297 [   24.274754] 3da0: 000000000000b89c 0000000000000000 00000032b5593519 ffffff8008081800 [   24.275438] 3dc0: 0000000000001000 0000000000000000 0000000034d5d91d 00000040ee841000 [   24.276123] 3de0: ffffff80096de2d0 0000000000000000 0000000000000000 0000000000000000 [   24.276807] 3e00: 0000000030d00800 000000059a1731e3 0000000000000001 ffffffc0f1d6bc00 [   24.277492] 3e20: 0000000000000001 ffffff80098a0ce0 0000000000000001 000000059a074c39 [   24.278177] 3e40: ffffff800983df50 000000000119323c 00000000017a001c ffffff80096d3ea0 [   24.278861] 3e60: ffffff8008c43cfc ffffff80096d3ea0 ffffff8008c43d00 0000000060000045 [   24.279546] 3e80: ffffff80096d3ea0 ffffff8008c43cfc ffffffffffffffff 0000000000000001 [   24.280230] [<ffffff80080827b4>] el1_irq+0xb4/0x140 [   24.280661] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254 [   24.281187] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44 [   24.281655] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78 [   24.282113] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac [   24.282626] [<ffffff8008f8cdd0>] rest_init+0x74/0x7c [   24.283063] [<ffffff80095a0bcc>] start_kernel+0x3d8/0x3fc [   24.283538] [<ffffff80095a01c4>] __primary_switched+0x30/0x6c
