OpenBSD on Pinebook - improving user experience
News:
- PWM driver was updated, now it should handle any periods (in nanoseconds), previous version was buggy and didn't support higher periods (but it was enough for the backlight): https://github.com/elewarr/openbsd-arm64...c4b0b09716
News:
- more PWM driver updates - it relies on new pwm_* methods recently introduced to OpenBSD kernel, yay!
- sxipwm and pwmbl drivers sent to tech@ (still work in progress but I'm quite happy about current state of sxipwm)
News:
- sxipwm/pwmbl drivers are now officially in OpenBSD!
- I prepared a new image with OpenBSD 6.6 (snapshot), introducing FVWM2 (based on this: https://github.com/addy-dclxvi/almighty-dotfiles)
https://wiki.pine64.org/index.php/1080P_...se#OpenBSD
.png   2019-10-22-231458_1920x1080_scrot.png (Size: 334.87 KB / Downloads: 673)
News:
Updated the pinebook image with latest updates (kernel and packages): https://wiki.pine64.org/index.php/1080P_...se#OpenBSD (image still uploading).
I modified u-boot configuration for pinebook a bit and it seems some boot reliability issues I had in the past are now gone.
(11-03-2019, 06:33 PM)elewarr Wrote: News:
Thanks on the update.
Hi @elewarr , I downloaded  from the wiki; I renamed it to fit better in my system (and modified the shasum accordingly); it downloaded correctly, but the file is corrupt:
$ shasum -c pinebook-openbsd-elewarr-2019-11-04.img.tgz.sha256
pinebook-openbsd-elewarr-2019-11-04.img.tgz: OK
$ tar -zxvf pinebook-openbsd-elewarr-2019-11-04.img.tgz
pinebook-2019-11-04.img
gzip: stdin: Input/output error
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
did Dropbox clip it?
I tried to use it anyway
$ time sudo dd if=pinebook-2019-11-04.img of=/dev/mmcblk0 bs=1M
6733+1 records in
6733+1 records out
7060880896 bytes (7.1 GB, 6.6 GiB) copied, 1240.21 s, 5.7 MB/s
real    20m40.229s
user    0m0.143s
sys    0m18.783s
and it booted up to xenodm Smile I like the default background you picked. Maybe there's some small set of corrupt and missing files as the end of the disk, but they don't seem to be impeding operation at all.
Thumbs Up NetBSD for Pinebook Luke 20 58,471 10-21-2020, 03:39 AM
Last Post: rckt
  FreeBSD for Pinebook e-minguez 4 12,883 10-14-2020, 05:12 PM
Last Post: zer0sig
Question OpenBSD 6.7 on Pinebook 1080p SKG 4 11,553 05-25-2020, 08:15 AM
Last Post: SKG
  OpenBSD on Pinebook 1080p? binholz 29 55,221 03-18-2020, 06:42 AM
Last Post: ab1jx
