New Stable release from Ayufan (0.8.3)
Hello
I have updated from 0.79 to 0.8.3 and everything is ok.
I have a stupid question : what is this red light always on beside the white light ?
Before, I had ony the white light, and now I have both.
Merci for your answer
Ross
(07-26-2019, 12:23 PM)Ross Wrote: Hello
Ross
Both the red and white LEDs are controllable by the OS and different images do different things with them
(07-19-2019, 05:58 PM)Faradn Wrote: [Using Mate' user/group management utility]
- Log in as rock64/rock64.
- Add user t3st3r1/what3v3r# with administrative rights.
- Log out rock64.
- Log in as t3st3r1/what3v3r#.
- Delete account rock64.
- Log out t3st3r1.
Now it's just the lightDM login screen with t3st3r1 and rock64 (??).
No mouse cursor.
Blinking '|' in password text edit.
I cannot log in.
Remote access with SSH works fine.
What can I do to get my t3st3r1 lightDM login to work?
Yesterday had similar problem with another distributive from parallel topic. I was able to login into Ctrl+Alt+F1 console but can't through display manager. It turns out that DM uses different characters than text console (and SSH client). You need explicitly setup your locale and language.
Sometimes it's better from the terminal.
>login is as rock64/rock64
>open a terminal
>Please type:
sudo useradd -m -s /bin/bash -G users,sudo t3st3r1
sudo passwd t3st3r1
>enter the new password
>log out and back in as the new user.
>Delete the rock64 account from a terminal with:
sudo userdel -r -f rock64
Hopefully that should be it Smile
Thanks,
Andy
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,635 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,975 04-23-2023, 01:32 PM
Last Post: diederik
  Armbian Jammy-Running fairly stable Rocklobster 0 2,962 05-04-2022, 01:00 PM
Last Post: Rocklobster
  Armbian 22.02 Release Announcement TRS-80 0 3,135 02-28-2022, 05:08 PM
Last Post: TRS-80
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,429 07-24-2021, 09:46 PM
Last Post: Mentaluproar
Big Grin Feature Complete Debian Desktop Release Mrfixit2001 158 303,959 05-29-2021, 04:05 AM
Last Post: twilite
  ayufan kernel update unbootable TheHunter 2 6,157 03-12-2021, 05:17 PM
Last Post: LMM
  Rockpro64 not stable... crashes now and then. Pineapple 18 34,420 02-16-2021, 02:45 PM
Last Post: TRS-80
Question Ayufan RockPro64 updates? hemertje 3 10,366 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 9,959 10-22-2020, 01:12 PM
