kernel comparison
I'm sure this has been asked before, but I can't seem to find it.  What are the differences between ayufan and mrfixit's kernels?
Nobody has written a comprehensive guide but you may be interested in looking at the git commit logs for the various projects
https://github.com/mrfixit2001/rockchip-...elease-4.4
https://github.com/mrfixit2001/debian_bu...its/master
https://github.com/ayufan-rock64/linux-b...its/master
https://github.com/ayufan-rock64/linux-k...se-4.4.184
What are YOU looking for?
Me, an aarch64 development system on which I can test the NEON extended instructions.
So, I want to see "neon" in /proc/cpuinfo
Also since the RK3399 has six cores, 4x A53 and 2x A72, I want to see that in /proc/cpuinfo.
AND since mainline Linux is at kernel 5.2.x and GCC is at 8.3.x, them too.
Mrfixit and Ayufan are doing kernel 4.4.xx and GCC Ver 7.3.
Manjaro is so far the best with kernel 5.1.x and GCC 8.2.x (an Arch spin off)
DietPi on RockPro64 Kernel 4.4.178, no neon in /proc/cpuinfo all exe's are ELF 64-bit LSB shared object, ARM aarch64
Ubuntu 18.04.2 LTS, kernel 4.4.167 No NEON in /proc/cpuinfo, gcc Ver 7.4.0 creates 64bit exe files
Debian, kernel from MrFixIt.
NetBSD, works but without GUI development libraries, way too hard to get my app going. NetBSD needs a repository for arm64, they are working on it.
Hello eard5849,
(07-10-2019, 05:49 AM)beard5849 Wrote: Me, an aarch64 development system on which I can test the NEON extended instructions.
see  bellow the links to ARM documentation..
Its related to NEON in ARMv7-A and ARMv7-R,
But maybe same behaviour( even though that there are changes between ARMv7 and ARMv8 )..
Sections 2.1.8 and 2.1.9:
NEON
Quote:A stock kernel is the kernel released by Linux at www.kernel.org, without modification.
If you use a Linux stock kernel to run your application, there is no need to manually enable the NEON unit.
The kernel automatically enables the NEON unit when it encounters the first NEON instruction.
If the NEON unit is disabled and the application tries to execute a NEON instruction, it throws an Undefined Instruction exception.
The kernel uses this exception to enable the NEON unit and then executes the NEON instruction.
The NEON unit remains enabled until there is a context switch.
When a context switch is required, the kernel might disable the NEON unit to save time and power.
Verify:
root@rockpro64:~# zcat /proc/config.gz | grep NEON CONFIG_KERNEL_MODE_NEON=y
(07-10-2019, 05:49 AM)beard5849 Wrote: Also since the RK3399 has six cores, 4x A53 and 2x A72, I want to see that in /proc/cpuinfo.
I see that in '/proc/cpuinfo'
root@rockpro64:~# cat /proc/cpuinfo processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd08 CPU revision : 2 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd08 CPU revision : 2 Serial : 0000000000000000 root@rockpro64:~# pwd /root root@rockpro64:~# git clone --branch master https://github.com/tuxd3v/tools.git && cd tools Cloning into 'tools'... remote: Enumerating objects: 44, done. remote: Counting objects: 100% (44/44), done. remote: Compressing objects: 100% (34/34), done. remote: Total 44 (delta 10), reused 42 (delta 8), pack-reused 0 Unpacking objects: 100% (44/44), done. root@rockpro64:~/tools# ./aarch mtune cortex-a72.cortex-a53
It is reported correctly
Regards,
tux
  Freezes and kernel panics with Debian trixie jssfr 4 4,241 04-15-2026, 06:48 PM
Last Post: prahal
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,244 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 7,063 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 4,639 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 4,429 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 5,260 09-11-2021, 08:58 PM
Last Post: t4_4t
  compiling a new kernel for overclocking on arch Mentaluproar 2 5,793 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 6,413 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 6,125 03-12-2021, 05:17 PM
Last Post: LMM
  Kernel oops after big-ish writes gaeb 1 4,588 02-11-2021, 03:55 PM
Last Post: gaeb
