Fan connector
Hello
I would like to connect a fan to the rockpro64 board, but I don't know the exact type of the board connector. Does anybody know which connector is compatible?
(06-19-2019, 04:05 PM)pc2005 Wrote: Hello
2mm PH type 2pin connector, here is the datasheet link: https://www.sparkfun.com/datasheets/Prototyping/ePH.pdf
thanks for the datasheet
  How do you connect PWM fan (3/4 pins) to this board (2 pin fan connector)? aleksei 3 12,675 11-19-2020, 04:35 PM
Last Post: Gienek
  connector type SPDIF FAN RTC battery? ChriChri 4 10,492 03-21-2020, 06:47 AM
Last Post: ChriChri
  MIPI CSI connector and FPC hitmantj 1 5,524 07-06-2018, 03:42 PM
Last Post: Bullet64
