Battery Powered
(04-11-2019, 08:41 PM)fysa Wrote: I don't believe the 12v is regulated, so you might have issues when the battery gets toward the lower end, but it's worked well for me for this project (and others).
TalentCell Rechargeable 72W 132WH 12V/11000mAh 9V/14500mAh 5V/26400mAh DC Output Lithium Ion Battery Pack For LED Strip and CCTV Camera, Portable Li-ion Power Bank, Black
Yes, it seems this battery (power bank) has non-regulated output from three Li-Ion cells. So the voltage on 12V pin may be in range of 9..12.6V, may be +/- 0.3V more to this limits due to voltage drop on switches/fuses/contacts/wires.
12V voltage is not used for the board components except by entry regulators, SY8113. Their datasheet saying that input voltage range is 4.5-16V. Of course, for 5V buck regulator output it has to be more than 5V. Having in mind 80mOhm top switch with a margin, the input voltage should be more than 6.0V to provide enough output current at 5V.
At lower voltage the efficiency of SY8113 buck converters is decreasing and the regulators may shutting down due to overheating.
In general, the ROCKPro64 board itself may operate from 9 to 16V DC voltage (make sure there are eliminated any possible spikes above 16V!). If you're using a devices which are supplying from 12V DC in, like a SATA drives, you need to check that devices separately.
I've checked ROCKPro64 schematic. There is a disagreement between Power diagram and DC IN & System power pages. At the first the regulators are designated as SY8113. At second they are TCS4313B. I haven't found the datasheet for TSC313B.
As for SY8113, it seems to me these regulators are OK for the board itself. But if you will try to load all USB ports and connect maximum peripherals, they become overloaded and my shut down suddenly. Not sure for TCS4313B. But this will be extreme case. For most of actual user configurations this circuitry is OK and commercially-efficient.
What do you think about it, guys? Can it be compatible with the RockPro64?
https://www.einhell.com.tr/shop/en-tr/cc-js-12.html
(06-07-2019, 08:06 AM)bobdaroze Wrote: What do you think about it, guys? Can it be compatible with the RockPro64?
Jump starts ROCKPro64 SBC :-)
Based on the description, may works with Rockpro64.
I'm using this battery pack: ie=UTF8&psc=1https://www.amazon.com/gp/product/B00ME3ZH7C/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
with this regulator: https://www.amazon.com/Voltage-Stabilize...194&sr=1-4
Now onto the real issue: power management are there any built in functions to clue the OS into what's going on?
Smile With that battery pack and regulator you are using.(1) You have clear picture of how connected?  also what is battery life for usage if I use regular monitor?
thanks sooo much EVERYONE!  (Sorry, I was away due to medical issues.)
I'm using this battery pack: ie=UTF8&psc=1https://www.amazon.com/gp/product/B00ME3...UTF8&psc=1
@duckkcud @RockPro64Newbie
Sorry for not responding earlier.
I can certainly send a picture, but I'm not sure it'll help much. Basically what I have is a 12v solar setup, and the output of the batteries are going to one of these regulator boards (which will either step the voltage up if it's low, or step it down if it's high) which then feeds into the rockpro64 + 2x powered USB hard drives (also running from the 12v supply).
https://www.ebay.com.au/itm/LTC3780-10A-...4116191949
I posted a power answer on the Pine-a64 section whilst thinking about a RockPro64, doh!
I have thought for a while that @ 12V $/Ah  lead acid are still extremely viable and the panel alarm batteries for the purpose of UPS size wise are not lithium compact but still for how we might use them compact.
I thought I would mention this as there are a rake of panels and equipment for this but focus seems to often be LiPo with limited current capacity with relatively small mAh and big $.
There are panels but this board I found interested me https://www.aliexpress.com/item/32953515494.html
Even branded NP7-12L Yuasa 12v 7Ah sealed lead acid battery cost approx £13
Add an I2C voltage current sense to the output https://www.ebay.co.uk/itm/302997431044
A charger circuit https://www.aliexpress.com/item/33050778041.html
Main voltage current sense is on battery output and optional voltage current sense on charger output.
That you have the basis of an extremely sophisticated UPS battery power system for £30, but much can be rescued from old alarm panels / emergency lighting.
(07-15-2019, 05:20 PM)RockPro64Newbie Wrote: Smile With that battery pack and regulator you are using.(1) You have clear picture of how connected?  also what is battery life for usage if I use regular monitor?
Hey, I'll take a pic when i get home.  The system that i have it connected to also has to power a lcd panel so I'm not sure how much this helps: I've had it on battery power for about an hour without it shutting down.  I have the batteries in it because the system is for my 5 year old and she likes to move her "kids computer" from our living room to her bedroom or over to a friend's house.  I haven't tested the system to failure.  The battery pack comes with a step down 5V USB outlet that i split to power the screen and a USB hub.  The 12V goes to the Rockpro.
  ROCKPro64 Battery Power Supply hoarfrosty 12 14,751 04-01-2024, 10:24 PM
Last Post: nano2
Question RockPro64 Lithium Battery Port TitleOS 0 3,366 12-05-2020, 12:35 AM
Last Post: TitleOS
  Can RockPro64 be powered via usb-c? pawlinski 2 6,436 10-16-2020, 07:27 AM
Last Post: pawlinski
  connector type SPDIF FAN RTC battery? ChriChri 4 10,316 03-21-2020, 06:47 AM
Last Post: ChriChri
  Rockpro64 12v Lipo battery for playbox? ScrumpyJack 0 3,244 09-18-2019, 01:25 AM
Last Post: ScrumpyJack
  USB powered externall hard drive not powering Shilelis 5 11,303 03-15-2019, 11:34 AM
Last Post: len
