Install Tensorflow
Good day everyone
I am trying to install tensorflow 1.12 on my PINE A64+LTS board
I have Xenial Mate OS which I downloaded from the following link
http://wiki.pine64.org/index.php/SOPINE_...re_Release
I used the following link to install Tensorflow 1.4, which worked
https://github.com/lherman-cs/tensorflow-aarch64
Later I found the wheel file for installing Tensorflow 1.12 in the following link
https://github.com/lhelontra/tensorflow-on-arm/releases
It didn't get installed and exited. I have attached the image of the terminal when this happened(Wheel Install)
I also found the following tutorial to build tensorflow
I followed this as well and it showed error when bazel was getting build. I have attached 2 images of the terminal when this happened (Build Install1, Build Install2)
I would appreciate if anyone would help me to install Tensorflow 1.12 or later on my Pine64
Thank you for your time.
Quote:I have Xenial Mate OS which I downloaded from the following link
You choose worst possible OS with a kernel 3.10.y ... Your best chances are with https://www.armbian.com/sopine-a64/
