New user - couple of issues
My 1080p Pinebook arrived this week. Here are my first few issues. Hopefully someone can help.
1. No audio device showing under the volume control on screen, and no sound.
2. Updating is failing. Looks like it wants me to provide credentials, but that pop up disappears immediately.
3. Trying to install Chrome, I get a dependency failure.
Any help would be appreciated.
Steve
I think there are known issues with some Linux distro's with regards to sound.
Are you familiar with the procedure of installing a new/different OS? You can run another OS directly from an SD card (leaving the internal EMMC alone) to test whether your audio issue is hardware or software related, and see if updates will work correctly there.
On Manjaro KDE, I've found this command helps with the audio issue. Problem is you have to run it after every boot.
pulseaudio -k
Smile New pinebook owner and user - ideas? trigger 6 13,606 04-29-2020, 07:38 PM
Last Post: tenderfoot
  Pinebook Issues DannyJack 6 12,124 05-18-2019, 09:54 AM
Last Post: Surehand53
  Is it possible to run x86 binaries on Pinebook via QEMU user space emulation? UltraBloxX 6 12,559 12-21-2018, 12:47 AM
Last Post: igorp
  1080p mainline kernel issues e-minguez 2 5,624 11-14-2018, 02:54 PM
Last Post: e-minguez
  Read if you experience issues with screen flickering Luke 18 41,844 10-15-2017, 06:43 AM
Last Post: Luke
