low speed wifi
Recently, i changed my internet connection to an optical fiber solution. For my internet connection, i use this wifi adapter bought with my rock64. I expected to get an important increase of the bandwidth, but the results are really bad; the maximum speed is: ~8 MBits for download, ~11MBits for upload althought my connections allows much more (on other computers i get at least 10 times more with wifi). I also tested this wifi adapter on a windows pc, and the performances are bad too.
Some one can explain this, or can recommand another usb2 wifi adapter?
regards
(04-15-2019, 02:56 AM)pas059 Wrote: Hello,
regards
What image are you using?
Any errors in dmesg or syslog?
That wifi adaptor should do 10+MBytes/s
hi,
i use armbian 5.65, but this adapter gives the same bad results on a pc under windows10.
some news on  my connections speeds...
I made other tests with armbian bionic 4.4.174 on a SD card and i obtain ~10Mbits/sec in both sens.
Strangely, when i boot from eMMC (ayfan bionic 4.4.132) i get a throughput of ~40 Mits/sec; that's better but it's far away from the results i get on a windows laptop (~200 Mbits/sec).
Why the internet throughput is lower when booting on a SD card Huh
but this is not all.
I also tested the internet throughput using the Gigabit connection. That's better than with wifi but far away from the results i get with (exactly) the same connection on a pc; and once again the throughput is half when booting on the SD card. So, when booting on the eMMC i get ~100 Mbits/sec (<50 Mbits when booting on the SDcard); this connection allows me to get an internet throughput of ~500 Mbits/sec on a windows pc. This is very disappointing from a Gigabit Ethernet interface, so much that one wonders if this is really a Gigabit ethernet interface Sad .
Someone have ideas or advices?
regards
here are some complementary informations, especialy concerning the Gigabit ethernet interface.
I made some test using iperf. With the Gigabit interface, i get ~800Mbits/sec with both ayfan bionic 4.4.132 on eMMc and with armbian on a SD; the throughput seems a little speeder when booting on the eMMC but this is not significant. It's reassuring Smile .
Always using iperf, the wifi throughput is ~2 times slower when booting on a SD.
Now concerning the internet throughput, it is always lower than 100 MBits/sec (using gigabit and booting on eMMc) although my internet connection allows 500 Mbits/sec (so 5 times lower), and again 2 times lower when booting on SD.
To resume, the internet throughput is really slow (even with gigabit ethernet), my wifi adaptor is also slow, and booting on a SD reduces by 2 the throughputs except for gigabit ethernet tranfers.
Any comments?
Heart Best quick/easy way to control case fan speed? idillicah 4 12,513 06-24-2021, 09:14 AM
Last Post: CounterPillow
  get wifi mt7601u mediatek usb dongle to work Johannes 0 6,758 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 17,829 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 37,832 05-13-2020, 05:03 PM
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 7,149 03-08-2019, 02:44 AM
Last Post: shripal17
Bug Fan speed controlled by CPU temp script mikedhoore 2 6,598 01-14-2019, 05:16 PM
Last Post: va88
  50 kb with RTL8188eu WIFI adapter Juice4 2 6,546 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 4,945 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 28,368 05-30-2018, 12:20 AM
Last Post: scalextrix
  Network Speed stuartiannaylor 27 52,697 05-06-2018, 10:07 AM
Last Post: S3phi40T
