Attaching a physical button to the ROCK64
Hi All,
I have downloaded the package that allows Python and GPIO interaction: https://github.com/mrfixit2001/Rock64-R64.GPIO
I have a button wired to the Ground pin and the pin 18 (https://www.cnx-software.com/wp-content/uploads/2017/08/Rock64-Pi-2-Bus-Pinout.png)
[/url]
so it looks like I am getting errors with my [url=https://pastebin.com/QpP1wgKH]script
(https://pastebin.com/QpP1wgKH).
errors appear after I ctrl-c in terminal, the two errors are:
Error: Unable to get GPIO value
You must setup() the GPIO channel (BCM 18) first
does anyone know what I am doing wrong?
take a look at this repo. it's a clone with some changes.
https://github.com/Matei-Ciobotaru/Rock64-R64.GPIO
another thing is you could use GPIO.BOARD instead of GPIO.BCM and maybe for test use value 18 instead of button.
  DeskPi case alternative for ROCK64 v1k699 2 13,233 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,563 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,496 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 48,603 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,308 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,935 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,637 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,579 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,969 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,942 06-08-2022, 12:44 AM
Last Post: Zoz
