Defect board?
Just got my first rockpro64 4gb. This is my first ever developer board, so I have no experience at all.
I plug in the power supply, and a green light turns on near the plug. Then i try to push the power button, and nothing happens.
I am wondering if this is a faulty board or if im doing something wrong? Huh
Start here -> http://wiki.pine64.org/index.php/ROCKPro...age_Builds
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Thanks for the response! Smile
I got it working now. The only thing i did was to flash the eMMC again. A bit embarrassing, but i thought it was going to give me some sort of display even without eMMC/sd-card.
Thanks again for the help. Smile)
Question M.2 SSD not visible when connected via PCI-e board jimh227 4 9,917 07-18-2022, 10:18 PM
Last Post: zer0sig
  How do you connect PWM fan (3/4 pins) to this board (2 pin fan connector)? aleksei 3 12,591 11-19-2020, 04:35 PM
Last Post: Gienek
  Getting 12v from the board domih 2 7,068 06-14-2019, 08:02 PM
Last Post: domih
  PCI-E Graphics Board Possible? Diesel141 1 4,805 04-23-2019, 12:13 AM
Last Post: Bullet64
  Discovered issues with PCIe NVMe & GPU Load in desktop 4.4.174 causing board lockup axelf 0 3,547 04-08-2019, 03:51 PM
Last Post: axelf
