Is my Rock64 is dead ?
Hi, I have a problem with my Rock64 and I would like to know your opinion and if it is possible to find a solution.
Until 2 months ago, I was using my Rock64 as an Android TV, it wasn't constantly plugged in. Then I couldn't use it since, so I put it in my desk (in a drawer).
I now have time again and I would like to use it again except... there is a problem. When I plug in the (original) plug the all the rock64 LEDs start flashing, and nothing happens on the screen, on the power supply I can hear a little "click". So I thought that the problem came from the power supply, even if it's strange, I made a multimeter measurement, I have 5~5.2V at the output.
I then checked the physical integrity of the ROCK64 and except for a few strange little "dirt" (because it was well stored).
Global picture :
https://cdn.discordapp.com/attachments/2...001728.jpg
Strange "dirt" :
https://cdn.discordapp.com/attachments/2...nknown.png
Side 2 :
https://cdn.discordapp.com/attachments/2...002539.jpg
I can't tell if it is rust or not, it's strange, inside a desk and there is no "water source" or anything near.
Tested with and without SD Card, with and without emmc and it still the same.
Do you think i can do something to fix it ? i love that device, i'm so sad it's not working anymore, I've always made sure to store it properly so it doesn't get damaged and in the end I feel like it's worse than better.
(01-31-2019, 05:42 PM)totalgaara Wrote: Hi, I have a problem with my Rock64 and I would like to know your opinion and if it is possible to find a solution.
Global picture :
Strange "dirt" :
Side 2 :
from photo, can tell what type of dirt. The location is close to USB 3.0 host port, if affected, should be only USB 3.0 not working. If you have serial console, please check on boot up log message to determine where is going wrong. If you don't have serial console, then just reprogram OS to another microSD card to check whether able to boot up again.
Hi, i cleaned the dirt this morning, i don't think it was some rust or anything, it's very strange...
I don't have a serial console. I tried with a SD Card (witch don't contain any OS), with the EMMC (with android 7.1) and with nothing. I've recorded some video, maybe it can help
With the EMMC only
With the SD Card Only  :
https://youtu.be/Vu9Lwyq2QkA
And without any storage :
https://youtu.be/dyatTWkX6fA
As you/i can see it's always the same, i can also hear something coming from the rock64, i hope we can ear it on the video
PS : It's not a issue with my phone, all the leds are blinking
(02-01-2019, 06:03 AM)totalgaara Wrote: Hi, i cleaned the dirt this morning, i don't think it was some rust or anything, it's very strange...
With the EMMC only
The green LED not suppose to blink. When blink, it means the ROCK64 somehow withdraw a lot of current from power supply that cause power supply trigger its over current protection circuit, or another situation is the power supply itself may suffer some defect. This is the guess finding from your short video.
I don't know what to do, have you any idea of what i can check ?
Thank you
(02-08-2019, 04:40 PM)totalgaara Wrote: I don't know what to do, have you any idea of what i can check ?
Thank you
To me it seams like a short circuit check some capacitors in your board.
Try to find some hot components i usually use some isopropyl alcohol to see ware it evaporates first or some compressed air. If you don't have any try with your hand and a multimeter.
I've some good news, it's alive Smile
I tested the PSU with a resistor and mesure the voltage with my multimeter, it was completly garbadge like if it was plug'in into the rock64
3,2V ; 1,8V ; 5V etc etc non stop changing
I cut the PSU cable and connected it to a classroom modular PSU, set 5V and current limit at 3A and it works like a charm.
Buying a new powersupply from the pinestore is not really a good idea for me because of exportation, it will cost me more than 20$ for the PSU + time for delivering
I'm asking, could i cut the wire of my raspberry pi official charger and use it for my rock64 ? or should i buy that on amazon :
https://www.amazon.fr/BERLS-dalimentatio...s=DC+5v+3A
Once it's within the required voltage/amps specs that shouldn't be a problem. I'm running my Roock64 on an old webcam power supply with no difficulties but I don't use any peripherals that require powering directly from the Rock64 USB ports.
my rpi kit had a 1.5 amp power supply. if yours still has a sticker on it read the output should be 5v and current like 650mA or 1.5Amp or whatever, you should try to have at least 3A. you can get a usb microB to 1.1mil barrel adapter if you got the money, that way your supply is not modified. your barrel , i think , is 3.5mm o.d. x 1.35mm i.d. and the link you posted has that.
I just bought that on amazon :
https://www.amazon.fr/gp/product/B07D1LC...UTF8&psc=1
it's working fine right now Smile i'm happy
  DeskPi case alternative for ROCK64 v1k699 2 12,010 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,748 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,896 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 45,408 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 10,230 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,295 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 20,050 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 5,809 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,166 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,169 06-08-2022, 12:44 AM
Last Post: Zoz
